Can't Start nclaunch of LDV 5.1 from The Linux Terminal
error while loading shared libraries lib ldv
I meet this problem too in my system .
my system is redhat 7.2 usr bash
I have set LD_LIBRARY_PATH to ${LDV_INST_DIR}/tools/lib in .bashrc
the error still
libvisadev.so mmsim
I am running on Linux Fedora Core 2. I too am facing this problem
ncsim: error while loading shared libraries: libudm.so: cannot open shared object file: No such file or directory
ncverilog: *E,SIMERR: Error during Simulation (status 127), exiting.
How to get rid of this problem?
Any suggestions mates?
Thanks in advance.
Regards,
- Satya
Added after 11 minutes:
I cant find the above mentioned package in cadence ftp. (ISR200401231650_LDV51_lnx86_1of1.tar).
I am looking into the following directory :
[R] 257 "/drac_japan/ldv/ncv" is current directory.
[R] List (cached)
[R] List Complete: 42 KB in 0.41 seconds (103.7 KB/s)
[R] CWD /drac_japan/ldv/ncv/ISR200401231650_LDV51_lnx86_1of1.tar.gz
[R] 550 /drac_japan/ldv/ncv/ISR200401231650_LDV51_lnx86_1of1.tar.gz: No such file or directory.
I am unable to find the file in above dir.
Please help mates.
thanks in advance.
Regards,
- Satya
you problem is the seting of LD_LIBRARY_PATH
I already set LD_LIBRARY_PATH to <inst_dir>/tools.lnx86/lib
Thanks
Regards,
- Satya
Added after 1 minutes:
Eventhough I set LD_LIBRARY_PATH I still get the error.
Give the following a try.
Use these cmds to search for the location of the lacking stuff.
$> su root <cr>
$> find / -name libudm.so -print <cr>
Append the <path> directory of libudm.so into the LD_LIBRARY_PATH environment. If there are mutiple findings, then choose the appropriate one to use for.
I was able to get rid of this libudm.so error by setting LD_LIBRARY_PATH variable.
But when I run ncsim it throws another error....
ncverilog: 05.10-s006: (c) Copyright 1995-2004 Cadence Design Systems, Inc.
Loading snapshot worklib.fa:v .................... Done
ncsim: *W,TCLINT: TCL init scripts not found, check TCL_LIBRARY.
ncsim> run
ncsim: *W,RNQUIE: Simulation is complete.
ncsim> exit
Can anybody suggest me how to get rid of this?
Thanks in advance.
Regards,
- Satya
I had a similar problem when I tried to run regressions via the AT command. It wasn't picking up my environment variables - specifically the LD_LIBRARY_PATH. I also had an incompatibility problem which I deleted the INCA_Libs directory and then it worked fine.
If you're getting the libudm.so error, it's probably a problem with you environment variables.
Eric
You may solve this problem by following steps. For example, I met this case:
>nclaunch
/usr/local/eda/ldv51/tools.lnx86/nclaunch/bin/nclaunch.exe: error while loading shared libraries: libvisadev.so: cannot open shared object file: No such file or directory
then exceute the following command:
> find LDV51_INSTALL_DIRECTORY -name libudm.so -print <cr>
you'll get
LDV51_INSTALL_DIRECTORY/tools.lnx86/inca/lib/libvisadev.so
then add LDV51_INSTALL_DIRECTORY/tools.lnx86/inca/lib/ to LD_LIBRARY_PATH, such as
setenv LD_LIBRARY_PATH $CADENCE/tools/lib
setenv LD_LIBRARY_PATH $CADENCE/tools/dfII/lib:$LD_LIBRARY_PATH
setenv LD_LIBRARY_PATH $CADENCE/tools/simcontrol/lib:$LD_LIBRARY_PATH
# add the next line, where $CADENCE is just LDV51_INSTALL_DIRECTORY
setenv LD_LIBRARY_PATH $CADENCE/tools/inca/lib:$LD_LIBRARY_PATH
setenv LD_LIBRARY_PATH /lib:/usr/lib:/usr/dt/lib:$LD_LIBRARY_PATH
good luck!
Yeah, replay after two years, bu I do met the same thing, and solved it by the help of the tips
egon said:
hi sunny656,
i couldn´t found LDV 5.1 ISR on the cadence ftp server.
There are only complete and overlay packets.
Please tell me the directory path.
Thank
it's gone for a long time. The oldest version is IUS 54
hi. I had the same problem.
and I had already set the LIBPATH to /tools.lnx86/lib which contained the libudm.so file.
Pls anyone can help me to fix it.
thanks.
After installation of IC6 & mmsim, I met a similar problem.
Having trying to start simulation from ADE it replied as:
*Error* The 'spectre' executable that you are using is an older version.
Use MMSIM60 or later version of Spectre with this release.
To check the spectre version, run 'spectre -W'
Typing 'spectre -W' in the terminal gave:
necessity to have the library 'libvisadev.so'.
As soon as I found this library in the hierarchy of cds6, I set
LD_LIBRARY_PATH=$CDS_INST_DIR/tools/dfII/verilogIn/lib
After that 'spectre -W' gives
sub-version 7.1.x.x
Nevertheless nothing changed at simulation starting in ADE.
But although standalone starting spectre works fiine.
Are there any suggestions to fix?
Thanks in advance.
