[SOLVED] Can you identify that Wires to PCB connector
PierreFromMontreal
Newbie level 6
These connectors are called as Relimate Connectors with 2.54mm pitch. You can just google it or else you can search from the manufacturers like JST.
I was crazy enough to contact the manufacturer and here is his answer
This connector is called PH2.0-3P, we use it from a Chinese local supplier. I found one similar on Ali. You can contact with the dealer for its matching plug.
https://www.aliexpress.com/item/PH2-0-3-Pin-Connector-Kits-2-0MM-Connector-Male-Pin-Header-Terminal-Female-Housing-PH2/32393653014.html?spm=2114.01010208.3.27.k3WWfM&ws_ab_test=searchweb201556_3,searchweb201644_3_10014_10001_10002_10005_301_10006_10003_10004_62,searchweb201560_1,searchweb1451318400_6150,searchweb1451318411_6448
