can we use Java language in Embedded microcontroller programming
gopi the king
Junior Member level 2
Coimbatore, Tamil Nadu, India
since i am an Embedded developer with 2 years experience in "C" language but now i have an opportunity to learn java. is Java language is useful in Embedded system ???
is there is any use of investing time in learning Java ???
i want to know ... if i learn java programming .. it will be useful in Embedded system micro-controller programming ??
give your opinion about this issue..............
More and more, it is notorious the increase use of microcontrollers based on latest ARM generation platforms, such as Cortex A8, on in relatively low cost embedded systems. Such systems allow the installation of high level operating systems, such as Linux or even WindowsCE.
Therefore, I personally consider appropriate to you invest in that language.
