[SOLVED] Can u help me to convert my C programm to hex code for PIC microcontroler..?????
pradeep_k_b
Full Member level 3
Nilambur, India
hi...
can somebody help me to convert this code to hex code?
i m using pic 16f690 and hitech c language
i have tried many times but still cant work
..pls help me..
//  File Name    : servo.c
//  Version      : 1.0
//  Description  : Servo Motor Controller
//                 Using TIMER0 for Generating Servo PWM
//  Target       : PICJazz 16F690 Board
//  Compiler     : HITECT PICC-Lite Version 9.60PL1
//  IDE          : Microchip MPLAB IDE v8.00
#include <pic.h>
/*   PIC Configuration Bit:
**   INTIO     - Using Internal RC No Clock
**   WDTDIS    - Wacthdog Timer Disable
**   PWRTEN    - Power Up Timer Enable
**   MCLREN    - Master Clear Enable
**   UNPROTECT - Code Un-Protect
**   UNPROTECT - Data EEPROM Read Un-Protect
**   BORDIS    - Borwn Out Detect Disable
**   IESODIS   - Internal External Switch Over Mode Disable
**   FCMDIS    - Monitor Clock Fail Safe Disable
__CONFIG(INTIO & WDTDIS & PWRTEN & MCLREN & UNPROTECT \
  & UNPROTECT & BORDIS & IESODIS & FCMDIS);
// Using Internal Clock of 8 Mhz
#define FOSC 8000000L
// Servo definition and variables
#define MAX_VALUE 200
#define CCW_ROTATION MAX_VALUE - 20
#define CW_ROTATION MAX_VALUE - 10
#define STOP_ROTATION MAX_VALUE
#define THRESHOLD_VALUE 50
unsigned char pulse_max=0;
unsigned char pulse_top=0;
unsigned char top_value = 0;
static void interrupt isr(void)
  if(T0IF) {	            // TIMER0 Interrupt Flag
    pulse_max++;            // Pulse Max Increment
    pulse_top++;            // Pulse Top Increment
    /* MAX_VALUE=200 turn off the pulse */
    if (pulse_max >= MAX_VALUE) {
      pulse_max=0;
      pulse_top=0;
      RC2=0;                // Turn off RC2
    /* top_value = MAX_VALUE - n, n=10: 10 x 0.1ms = 1.0ms, n=20: 20 x 0.1ms = 2.0ms */
    /* 2ms -> CCW Rotation, 1ms -> CW Rotation */
    if (pulse_top == top_value) {
      RC2=1;                // Turn On RC2
    TMR0 = 156;             // Initial Value for 0.1ms Interrupt
    T0IF = 0;		    // Clear TIMER0 interrupt flag
void main(void)
  unsigned char ldr_left;
  unsigned char ldr_right;
  int ldr_diff;
  OSCCON=0x70;         // Select 8 Mhz internal clock
  /* Initial Port Used */
  TRISC = 0x03;        // Set RC0 and RC1 as input others as Output
  ANSEL = 0x30;        // Set PORT AN4 and AN5 as analog input
  ANSELH = 0x00;       // Set PORT AN8 to AN11 as Digital I/O
  PORTC = 0x00;        // Turn Off all PORTC
  /* Init Servo Pulse */
  pulse_max=0;
  pulse_top=0;
  top_value = MAX_VALUE; // top_value = MAX_VALUE: Servo Motor Stop
  /* Initial ADC */
  ADCON1=0b00110000;   // Select the FRC for 8 Mhz
  /* Init TIMER0: Period: Fosc/4 x Prescaler x TMR0
     0.0005 ms x 2 * 100 = 0.1 ms */
  OPTION = 0b00000000; // 1:2 Prescaller
  TMR0=156;            // Interupt every 0.1 ms
  T0IE = 1;		       // Enable interrupt on TMR0 overflow
  GIE = 1;		       // Global interrupt enable
  for(;;) {
    /* Read the ADC here */
    ADCON0=0b00010001;       // select left justify result. ADC port channel AN4
    GODONE=1;	             // initiate conversion on the channel 4
    while(GODONE) continue;  // Wait for ldr_left conversion done
    ldr_left=ADRESH;         // Read 8 bits MSB, Ignore 2 bits LSB in ADRESL
    ADCON0=0b00010101;       // select left justify result. ADC port channel AN5
    GODONE=1;	             // initiate conversion on the channel 5
    while(GODONE) continue;  // Wait for ldr_right conversion done
    ldr_right=ADRESH;        // Read 8 bits MSB, Ignore 2 bits LSB in ADRESL
    /* Get the different */
    ldr_diff=ldr_left - ldr_right;
    if ((ldr_diff >= -THRESHOLD_VALUE) && (ldr_diff <= THRESHOLD_VALUE)) {
      top_value = MAX_VALUE;     // Stop the Servo Motor
    } else {
      if (ldr_diff > THRESHOLD_VALUE) {
        top_value = CCW_ROTATION;  // Counterclockwise Rotation
      } else {
        top_value = CW_ROTATION;   // Clockwise Rotation
/* EOF: servo.c */
The code you have posted utilizes legacy SFR and Configuration Bit Masks.
Examine the device specific header file, pic16f690.h, for the current nomenclature and substitute accordingly.
pic16f690.h
#ifndef	_HTC_H_
#warning Header file pic16f690.h included directly. Use #include <htc.h> instead.
#endif
/* header file for the MICROCHIP PIC microcontroller
 *  16F690
#ifndef __PIC16F690_H
#define __PIC16F690_H
// Configuration mask definitions
// Config Register: CONFIG
#define CONFIG               0x2007
// Oscillator Selection bits
// RC oscillator: CLKOUT function on RA4/OSC2/CLKOUT pin, RC on RA5/OSC1/CLKIN
#define FOSC_EXTRCCLK        0xFFFF
// RCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, RC on RA5/OSC1/CLKIN
#define FOSC_EXTRCIO         0xFFFE
// INTOSC oscillator: CLKOUT function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN
#define FOSC_INTRCCLK        0xFFFD
// INTOSCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN
#define FOSC_INTRCIO         0xFFFC
// EC: I/O function on RA4/OSC2/CLKOUT pin, CLKIN on RA5/OSC1/CLKIN
#define FOSC_EC              0xFFFB
// HS oscillator: High-speed crystal/resonator on RA4/OSC2/CLKOUT and RA5/OSC1/CLKIN
#define FOSC_HS              0xFFFA
// XT oscillator: Crystal/resonator on RA4/OSC2/CLKOUT and RA5/OSC1/CLKIN
#define FOSC_XT              0xFFF9
// LP oscillator: Low-power crystal on RA4/OSC2/CLKOUT and RA5/OSC1/CLKIN
#define FOSC_LP              0xFFF8
// Watchdog Timer Enable bit
// WDT enabled
#define WDTE_ON              0xFFFF
// WDT disabled and can be enabled by SWDTEN bit of the WDTCON register
#define WDTE_OFF             0xFFF7
// Power-up Timer Enable bit
// PWRT disabled
#define PWRTE_OFF            0xFFFF
// PWRT enabled
#define PWRTE_ON             0xFFEF
// MCLR Pin Function Select bit
// MCLR pin function is MCLR
#define MCLRE_ON             0xFFFF
// MCLR pin function is digital input, MCLR internally tied to VDD
#define MCLRE_OFF            0xFFDF
// Code Protection bit
// Program memory code protection is disabled
#define CP_OFF               0xFFFF
// Program memory code protection is enabled
#define CP_ON                0xFFBF
// Data Code Protection bit
// Data memory code protection is disabled
#define CPD_OFF              0xFFFF
// Data memory code protection is enabled
#define CPD_ON               0xFF7F
// Brown-out Reset Selection bits
// BOR enabled
#define BOREN_ON             0xFFFF
// BOR enabled during operation and disabled in Sleep
#define BOREN_NSLEEP         0xFEFF
// BOR controlled by SBOREN bit of the PCON register
#define BOREN_SBODEN         0xFDFF
// BOR disabled
#define BOREN_OFF            0xFCFF
// Internal External Switchover bit
// Internal External Switchover mode is enabled
#define IESO_ON              0xFFFF
// Internal External Switchover mode is disabled
#define IESO_OFF             0xFBFF
// Fail-Safe Clock Monitor Enabled bit
// Fail-Safe Clock Monitor is enabled
#define FCMEN_ON             0xFFFF
// Fail-Safe Clock Monitor is disabled
#define FCMEN_OFF            0xF7FF
// Special function register definitions
// Register: INDF
volatile unsigned char           INDF                @ 0x000;
// bit and bitfield definitions
// Register: TMR0
volatile unsigned char           TMR0                @ 0x001;
// Register: PCL
volatile unsigned char           PCL                 @ 0x002;
// Register: STATUS
volatile unsigned char           STATUS              @ 0x003;
volatile bit CARRY               @ ((unsigned)&STATUS*8)+0;
volatile bit DC                  @ ((unsigned)&STATUS*8)+1;
volatile bit ZERO                @ ((unsigned)&STATUS*8)+2;
volatile bit nPD                 @ ((unsigned)&STATUS*8)+3;
volatile bit nTO                 @ ((unsigned)&STATUS*8)+4;
volatile bit IRP                 @ ((unsigned)&STATUS*8)+7;
volatile bit RP0                 @ ((unsigned)&STATUS*8)+5;
volatile bit RP1                 @ ((unsigned)&STATUS*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	C                   : 1;
        unsigned	DC                  : 1;
        unsigned	Z                   : 1;
        unsigned	nPD                 : 1;
        unsigned	nTO                 : 1;
        unsigned	RP                  : 2;
        unsigned	IRP                 : 1;
    struct {
        unsigned	                    : 5;
        unsigned	RP0                 : 1;
        unsigned	RP1                 : 1;
} STATUSbits @ 0x003;
#endif
// Register: FSR
volatile unsigned char           FSR                 @ 0x004;
// Register: PORTA
volatile unsigned char           PORTA               @ 0x005;
volatile bit RA0                 @ ((unsigned)&PORTA*8)+0;
volatile bit RA1                 @ ((unsigned)&PORTA*8)+1;
volatile bit RA2                 @ ((unsigned)&PORTA*8)+2;
volatile bit RA3                 @ ((unsigned)&PORTA*8)+3;
volatile bit RA4                 @ ((unsigned)&PORTA*8)+4;
volatile bit RA5                 @ ((unsigned)&PORTA*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RA0                 : 1;
        unsigned	RA1                 : 1;
        unsigned	RA2                 : 1;
        unsigned	RA3                 : 1;
        unsigned	RA4                 : 1;
        unsigned	RA5                 : 1;
} PORTAbits @ 0x005;
#endif
// Register: PORTB
volatile unsigned char           PORTB               @ 0x006;
volatile bit RB4                 @ ((unsigned)&PORTB*8)+4;
volatile bit RB5                 @ ((unsigned)&PORTB*8)+5;
volatile bit RB6                 @ ((unsigned)&PORTB*8)+6;
volatile bit RB7                 @ ((unsigned)&PORTB*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 4;
        unsigned	RB4                 : 1;
        unsigned	RB5                 : 1;
        unsigned	RB6                 : 1;
        unsigned	RB7                 : 1;
} PORTBbits @ 0x006;
#endif
// Register: PORTC
volatile unsigned char           PORTC               @ 0x007;
volatile bit RC0                 @ ((unsigned)&PORTC*8)+0;
volatile bit RC1                 @ ((unsigned)&PORTC*8)+1;
volatile bit RC2                 @ ((unsigned)&PORTC*8)+2;
volatile bit RC3                 @ ((unsigned)&PORTC*8)+3;
volatile bit RC4                 @ ((unsigned)&PORTC*8)+4;
volatile bit RC5                 @ ((unsigned)&PORTC*8)+5;
volatile bit RC6                 @ ((unsigned)&PORTC*8)+6;
volatile bit RC7                 @ ((unsigned)&PORTC*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RC0                 : 1;
        unsigned	RC1                 : 1;
        unsigned	RC2                 : 1;
        unsigned	RC3                 : 1;
        unsigned	RC4                 : 1;
        unsigned	RC5                 : 1;
        unsigned	RC6                 : 1;
        unsigned	RC7                 : 1;
} PORTCbits @ 0x007;
#endif
// Register: PCLATH
volatile unsigned char           PCLATH              @ 0x00A;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 5;
} PCLATHbits @ 0x00A;
#endif
// Register: INTCON
volatile unsigned char           INTCON              @ 0x00B;
volatile bit RABIF               @ ((unsigned)&INTCON*8)+0;
volatile bit INTF                @ ((unsigned)&INTCON*8)+1;
volatile bit T0IF                @ ((unsigned)&INTCON*8)+2;
volatile bit RABIE               @ ((unsigned)&INTCON*8)+3;
volatile bit INTE                @ ((unsigned)&INTCON*8)+4;
volatile bit T0IE                @ ((unsigned)&INTCON*8)+5;
volatile bit PEIE                @ ((unsigned)&INTCON*8)+6;
volatile bit GIE                 @ ((unsigned)&INTCON*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RABIF               : 1;
        unsigned	INTF                : 1;
        unsigned	T0IF                : 1;
        unsigned	RABIE               : 1;
        unsigned	INTE                : 1;
        unsigned	T0IE                : 1;
        unsigned	PEIE                : 1;
        unsigned	GIE                 : 1;
} INTCONbits @ 0x00B;
#endif
// Register: PIR1
volatile unsigned char           PIR1                @ 0x00C;
volatile bit TMR1IF              @ ((unsigned)&PIR1*8)+0;
volatile bit TMR2IF              @ ((unsigned)&PIR1*8)+1;
volatile bit CCP1IF              @ ((unsigned)&PIR1*8)+2;
volatile bit SSPIF               @ ((unsigned)&PIR1*8)+3;
volatile bit TXIF                @ ((unsigned)&PIR1*8)+4;
volatile bit RCIF                @ ((unsigned)&PIR1*8)+5;
volatile bit ADIF                @ ((unsigned)&PIR1*8)+6;
volatile bit T1IF                @ ((unsigned)&PIR1*8)+0;
volatile bit T2IF                @ ((unsigned)&PIR1*8)+1;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TMR1IF              : 1;
        unsigned	TMR2IF              : 1;
        unsigned	CCP1IF              : 1;
        unsigned	SSPIF               : 1;
        unsigned	TXIF                : 1;
        unsigned	RCIF                : 1;
        unsigned	ADIF                : 1;
    struct {
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	                    : 2;
        unsigned	: 1;
    struct {
        unsigned	T1IF                : 1;
        unsigned	T2IF                : 1;
} PIR1bits @ 0x00C;
#endif
// Register: PIR2
volatile unsigned char           PIR2                @ 0x00D;
volatile bit EEIF                @ ((unsigned)&PIR2*8)+4;
volatile bit C1IF                @ ((unsigned)&PIR2*8)+5;
volatile bit C2IF                @ ((unsigned)&PIR2*8)+6;
volatile bit OSFIF               @ ((unsigned)&PIR2*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 4;
        unsigned	EEIF                : 1;
        unsigned	C1IF                : 1;
        unsigned	C2IF                : 1;
        unsigned	OSFIF               : 1;
} PIR2bits @ 0x00D;
#endif
// Register: TMR1L
volatile unsigned char           TMR1L               @ 0x00E;
// Register: TMR1H
volatile unsigned char           TMR1H               @ 0x00F;
// Register: TMR1
volatile unsigned int            TMR1                @ 0x00E;
// Register: T1CON
volatile unsigned char           T1CON               @ 0x010;
volatile bit TMR1ON              @ ((unsigned)&T1CON*8)+0;
volatile bit TMR1CS              @ ((unsigned)&T1CON*8)+1;
volatile bit nT1SYNC             @ ((unsigned)&T1CON*8)+2;
volatile bit T1OSCEN             @ ((unsigned)&T1CON*8)+3;
volatile bit TMR1GE              @ ((unsigned)&T1CON*8)+6;
volatile bit T1GINV              @ ((unsigned)&T1CON*8)+7;
volatile bit T1CKPS0             @ ((unsigned)&T1CON*8)+4;
volatile bit T1CKPS1             @ ((unsigned)&T1CON*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TMR1ON              : 1;
        unsigned	TMR1CS              : 1;
        unsigned	nT1SYNC             : 1;
        unsigned	T1OSCEN             : 1;
        unsigned	T1CKPS              : 2;
        unsigned	TMR1GE              : 1;
        unsigned	T1GINV              : 1;
    struct {
        unsigned	                    : 4;
        unsigned	T1CKPS0             : 1;
        unsigned	T1CKPS1             : 1;
} T1CONbits @ 0x010;
#endif
// Register: TMR2
volatile unsigned char           TMR2                @ 0x011;
// Register: T2CON
volatile unsigned char           T2CON               @ 0x012;
volatile bit TMR2ON              @ ((unsigned)&T2CON*8)+2;
volatile bit T2CKPS0             @ ((unsigned)&T2CON*8)+0;
volatile bit T2CKPS1             @ ((unsigned)&T2CON*8)+1;
volatile bit TOUTPS0             @ ((unsigned)&T2CON*8)+3;
volatile bit TOUTPS1             @ ((unsigned)&T2CON*8)+4;
volatile bit TOUTPS2             @ ((unsigned)&T2CON*8)+5;
volatile bit TOUTPS3             @ ((unsigned)&T2CON*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	T2CKPS              : 2;
        unsigned	TMR2ON              : 1;
        unsigned	TOUTPS              : 4;
    struct {
        unsigned	T2CKPS0             : 1;
        unsigned	T2CKPS1             : 1;
        unsigned	                    : 1;
        unsigned	TOUTPS0             : 1;
        unsigned	TOUTPS1             : 1;
        unsigned	TOUTPS2             : 1;
        unsigned	TOUTPS3             : 1;
} T2CONbits @ 0x012;
#endif
// Register: SSPBUF
volatile unsigned char           SSPBUF              @ 0x013;
// Register: SSPCON
volatile unsigned char           SSPCON              @ 0x014;
volatile bit CKP                 @ ((unsigned)&SSPCON*8)+4;
volatile bit SSPEN               @ ((unsigned)&SSPCON*8)+5;
volatile bit SSPOV               @ ((unsigned)&SSPCON*8)+6;
volatile bit WCOL                @ ((unsigned)&SSPCON*8)+7;
volatile bit SSPM0               @ ((unsigned)&SSPCON*8)+0;
volatile bit SSPM1               @ ((unsigned)&SSPCON*8)+1;
volatile bit SSPM2               @ ((unsigned)&SSPCON*8)+2;
volatile bit SSPM3               @ ((unsigned)&SSPCON*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	SSPM                : 4;
        unsigned	CKP                 : 1;
        unsigned	SSPEN               : 1;
        unsigned	SSPOV               : 1;
        unsigned	WCOL                : 1;
    struct {
        unsigned	SSPM0               : 1;
        unsigned	SSPM1               : 1;
        unsigned	SSPM2               : 1;
        unsigned	SSPM3               : 1;
} SSPCONbits @ 0x014;
#endif
// Register: CCPR1L
volatile unsigned char           CCPR1L              @ 0x015;
// Register: CCPR1H
volatile unsigned char           CCPR1H              @ 0x016;
// Register: CCPR
volatile unsigned int            CCPR                @ 0x015;
// Register: CCP1CON
volatile unsigned char           CCP1CON             @ 0x017;
volatile bit CCP1M0              @ ((unsigned)&CCP1CON*8)+0;
volatile bit CCP1M1              @ ((unsigned)&CCP1CON*8)+1;
volatile bit CCP1M2              @ ((unsigned)&CCP1CON*8)+2;
volatile bit CCP1M3              @ ((unsigned)&CCP1CON*8)+3;
volatile bit DC1B0               @ ((unsigned)&CCP1CON*8)+4;
volatile bit DC1B1               @ ((unsigned)&CCP1CON*8)+5;
volatile bit P1M0                @ ((unsigned)&CCP1CON*8)+6;
volatile bit P1M1                @ ((unsigned)&CCP1CON*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	CCP1M               : 4;
        unsigned	DC1B                : 2;
        unsigned	P1M                 : 2;
    struct {
        unsigned	CCP1M0              : 1;
        unsigned	CCP1M1              : 1;
        unsigned	CCP1M2              : 1;
        unsigned	CCP1M3              : 1;
        unsigned	DC1B0               : 1;
        unsigned	DC1B1               : 1;
        unsigned	P1M0                : 1;
        unsigned	P1M1                : 1;
} CCP1CONbits @ 0x017;
#endif
// Register: RCSTA
volatile unsigned char           RCSTA               @ 0x018;
volatile bit RX9D                @ ((unsigned)&RCSTA*8)+0;
volatile bit OERR                @ ((unsigned)&RCSTA*8)+1;
volatile bit FERR                @ ((unsigned)&RCSTA*8)+2;
volatile bit ADDEN               @ ((unsigned)&RCSTA*8)+3;
volatile bit CREN                @ ((unsigned)&RCSTA*8)+4;
volatile bit SREN                @ ((unsigned)&RCSTA*8)+5;
volatile bit RX9                 @ ((unsigned)&RCSTA*8)+6;
volatile bit SPEN                @ ((unsigned)&RCSTA*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RX9D                : 1;
        unsigned	OERR                : 1;
        unsigned	FERR                : 1;
        unsigned	ADDEN               : 1;
        unsigned	CREN                : 1;
        unsigned	SREN                : 1;
        unsigned	RX9                 : 1;
        unsigned	SPEN                : 1;
} RCSTAbits @ 0x018;
#endif
// Register: TXREG
volatile unsigned char           TXREG               @ 0x019;
// Register: RCREG
volatile unsigned char           RCREG               @ 0x01A;
// Register: PWM1CON
volatile unsigned char           PWM1CON             @ 0x01C;
volatile bit PRSEN               @ ((unsigned)&PWM1CON*8)+7;
volatile bit PDC0                @ ((unsigned)&PWM1CON*8)+0;
volatile bit PDC1                @ ((unsigned)&PWM1CON*8)+1;
volatile bit PDC2                @ ((unsigned)&PWM1CON*8)+2;
volatile bit PDC3                @ ((unsigned)&PWM1CON*8)+3;
volatile bit PDC4                @ ((unsigned)&PWM1CON*8)+4;
volatile bit PDC5                @ ((unsigned)&PWM1CON*8)+5;
volatile bit PDC6                @ ((unsigned)&PWM1CON*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	PDC                 : 7;
        unsigned	PRSEN               : 1;
    struct {
        unsigned	PDC0                : 1;
        unsigned	PDC1                : 1;
        unsigned	PDC2                : 1;
        unsigned	PDC3                : 1;
        unsigned	PDC4                : 1;
        unsigned	PDC5                : 1;
        unsigned	PDC6                : 1;
} PWM1CONbits @ 0x01C;
#endif
// Register: ECCPAS
volatile unsigned char           ECCPAS              @ 0x01D;
volatile bit ECCPASE             @ ((unsigned)&ECCPAS*8)+7;
volatile bit PSSBD0              @ ((unsigned)&ECCPAS*8)+0;
volatile bit PSSBD1              @ ((unsigned)&ECCPAS*8)+1;
volatile bit PSSAC0              @ ((unsigned)&ECCPAS*8)+2;
volatile bit PSSAC1              @ ((unsigned)&ECCPAS*8)+3;
volatile bit ECCPAS0             @ ((unsigned)&ECCPAS*8)+4;
volatile bit ECCPAS1             @ ((unsigned)&ECCPAS*8)+5;
volatile bit ECCPAS2             @ ((unsigned)&ECCPAS*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	PSSBD               : 2;
        unsigned	PSSAC               : 2;
        unsigned	ECCPAS              : 3;
        unsigned	ECCPASE             : 1;
    struct {
        unsigned	PSSBD0              : 1;
        unsigned	PSSBD1              : 1;
        unsigned	PSSAC0              : 1;
        unsigned	PSSAC1              : 1;
        unsigned	ECCPAS0             : 1;
        unsigned	ECCPAS1             : 1;
        unsigned	ECCPAS2             : 1;
} ECCPASbits @ 0x01D;
#endif
// Register: ADRESH
volatile unsigned char           ADRESH              @ 0x01E;
// Register: ADCON0
volatile unsigned char           ADCON0              @ 0x01F;
volatile bit ADON                @ ((unsigned)&ADCON0*8)+0;
volatile bit GO_nDONE            @ ((unsigned)&ADCON0*8)+1;
volatile bit VCFG                @ ((unsigned)&ADCON0*8)+6;
volatile bit ADFM                @ ((unsigned)&ADCON0*8)+7;
volatile bit GO                  @ ((unsigned)&ADCON0*8)+1;
volatile bit CHS0                @ ((unsigned)&ADCON0*8)+2;
volatile bit CHS1                @ ((unsigned)&ADCON0*8)+3;
volatile bit CHS2                @ ((unsigned)&ADCON0*8)+4;
volatile bit CHS3                @ ((unsigned)&ADCON0*8)+5;
volatile bit nDONE               @ ((unsigned)&ADCON0*8)+1;
volatile bit GO_DONE             @ ((unsigned)&ADCON0*8)+1;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	ADON                : 1;
        unsigned	GO_nDONE            : 1;
        unsigned	CHS                 : 4;
        unsigned	VCFG                : 1;
        unsigned	ADFM                : 1;
    struct {
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 4;
        unsigned	: 1;
        unsigned	: 1;
    struct {
        unsigned	                    : 1;
        unsigned	GO                  : 1;
        unsigned	CHS0                : 1;
        unsigned	CHS1                : 1;
        unsigned	CHS2                : 1;
        unsigned	CHS3                : 1;
    struct {
        unsigned	: 1;
        unsigned	nDONE               : 1;
    struct {
        unsigned	: 1;
        unsigned	GO_DONE             : 1;
} ADCON0bits @ 0x01F;
#endif
// Special function register definitions: Bank 1
// Register: OPTION_REG
volatile unsigned char           OPTION_REG          @ 0x081;
volatile bit PSA                 @ ((unsigned)&OPTION_REG*8)+3;
volatile bit T0SE                @ ((unsigned)&OPTION_REG*8)+4;
volatile bit T0CS                @ ((unsigned)&OPTION_REG*8)+5;
volatile bit INTEDG              @ ((unsigned)&OPTION_REG*8)+6;
volatile bit nRABPU              @ ((unsigned)&OPTION_REG*8)+7;
volatile bit PS0                 @ ((unsigned)&OPTION_REG*8)+0;
volatile bit PS1                 @ ((unsigned)&OPTION_REG*8)+1;
volatile bit PS2                 @ ((unsigned)&OPTION_REG*8)+2;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	PS                  : 3;
        unsigned	PSA                 : 1;
        unsigned	T0SE                : 1;
        unsigned	T0CS                : 1;
        unsigned	INTEDG              : 1;
        unsigned	nRABPU              : 1;
    struct {
        unsigned	PS0                 : 1;
        unsigned	PS1                 : 1;
        unsigned	PS2                 : 1;
} OPTION_REGbits @ 0x081;
#endif
// Register: TRISA
volatile unsigned char           TRISA               @ 0x085;
volatile bit TRISA0              @ ((unsigned)&TRISA*8)+0;
volatile bit TRISA1              @ ((unsigned)&TRISA*8)+1;
volatile bit TRISA2              @ ((unsigned)&TRISA*8)+2;
volatile bit TRISA3              @ ((unsigned)&TRISA*8)+3;
volatile bit TRISA4              @ ((unsigned)&TRISA*8)+4;
volatile bit TRISA5              @ ((unsigned)&TRISA*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TRISA0              : 1;
        unsigned	TRISA1              : 1;
        unsigned	TRISA2              : 1;
        unsigned	TRISA3              : 1;
        unsigned	TRISA4              : 1;
        unsigned	TRISA5              : 1;
} TRISAbits @ 0x085;
#endif
// Register: TRISB
volatile unsigned char           TRISB               @ 0x086;
volatile bit TRISB4              @ ((unsigned)&TRISB*8)+4;
volatile bit TRISB5              @ ((unsigned)&TRISB*8)+5;
volatile bit TRISB6              @ ((unsigned)&TRISB*8)+6;
volatile bit TRISB7              @ ((unsigned)&TRISB*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 4;
        unsigned	TRISB4              : 1;
        unsigned	TRISB5              : 1;
        unsigned	TRISB6              : 1;
        unsigned	TRISB7              : 1;
} TRISBbits @ 0x086;
#endif
// Register: TRISC
volatile unsigned char           TRISC               @ 0x087;
volatile bit TRISC0              @ ((unsigned)&TRISC*8)+0;
volatile bit TRISC1              @ ((unsigned)&TRISC*8)+1;
volatile bit TRISC2              @ ((unsigned)&TRISC*8)+2;
volatile bit TRISC3              @ ((unsigned)&TRISC*8)+3;
volatile bit TRISC4              @ ((unsigned)&TRISC*8)+4;
volatile bit TRISC5              @ ((unsigned)&TRISC*8)+5;
volatile bit TRISC6              @ ((unsigned)&TRISC*8)+6;
volatile bit TRISC7              @ ((unsigned)&TRISC*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TRISC0              : 1;
        unsigned	TRISC1              : 1;
        unsigned	TRISC2              : 1;
        unsigned	TRISC3              : 1;
        unsigned	TRISC4              : 1;
        unsigned	TRISC5              : 1;
        unsigned	TRISC6              : 1;
        unsigned	TRISC7              : 1;
} TRISCbits @ 0x087;
#endif
// Register: PIE1
volatile unsigned char           PIE1                @ 0x08C;
volatile bit TMR1IE              @ ((unsigned)&PIE1*8)+0;
volatile bit TMR2IE              @ ((unsigned)&PIE1*8)+1;
volatile bit CCP1IE              @ ((unsigned)&PIE1*8)+2;
volatile bit SSPIE               @ ((unsigned)&PIE1*8)+3;
volatile bit TXIE                @ ((unsigned)&PIE1*8)+4;
volatile bit RCIE                @ ((unsigned)&PIE1*8)+5;
volatile bit ADIE                @ ((unsigned)&PIE1*8)+6;
volatile bit T1IE                @ ((unsigned)&PIE1*8)+0;
volatile bit T2IE                @ ((unsigned)&PIE1*8)+1;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TMR1IE              : 1;
        unsigned	TMR2IE              : 1;
        unsigned	CCP1IE              : 1;
        unsigned	SSPIE               : 1;
        unsigned	TXIE                : 1;
        unsigned	RCIE                : 1;
        unsigned	ADIE                : 1;
    struct {
        unsigned	T1IE                : 1;
        unsigned	T2IE                : 1;
} PIE1bits @ 0x08C;
#endif
// Register: PIE2
volatile unsigned char           PIE2                @ 0x08D;
volatile bit EEIE                @ ((unsigned)&PIE2*8)+4;
volatile bit C1IE                @ ((unsigned)&PIE2*8)+5;
volatile bit C2IE                @ ((unsigned)&PIE2*8)+6;
volatile bit OSFIE               @ ((unsigned)&PIE2*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 4;
        unsigned	EEIE                : 1;
        unsigned	C1IE                : 1;
        unsigned	C2IE                : 1;
        unsigned	OSFIE               : 1;
} PIE2bits @ 0x08D;
#endif
// Register: PCON
volatile unsigned char           PCON                @ 0x08E;
volatile bit nBOR                @ ((unsigned)&PCON*8)+0;
volatile bit nPOR                @ ((unsigned)&PCON*8)+1;
volatile bit SBOREN              @ ((unsigned)&PCON*8)+4;
volatile bit ULPWUE              @ ((unsigned)&PCON*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	nBOR                : 1;
        unsigned	nPOR                : 1;
        unsigned	                    : 2;
        unsigned	SBOREN              : 1;
        unsigned	ULPWUE              : 1;
} PCONbits @ 0x08E;
#endif
// Register: OSCCON
volatile unsigned char           OSCCON              @ 0x08F;
volatile bit SCS                 @ ((unsigned)&OSCCON*8)+0;
volatile bit LTS                 @ ((unsigned)&OSCCON*8)+1;
volatile bit HTS                 @ ((unsigned)&OSCCON*8)+2;
volatile bit OSTS                @ ((unsigned)&OSCCON*8)+3;
volatile bit IRCF0               @ ((unsigned)&OSCCON*8)+4;
volatile bit IRCF1               @ ((unsigned)&OSCCON*8)+5;
volatile bit IRCF2               @ ((unsigned)&OSCCON*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	SCS                 : 1;
        unsigned	LTS                 : 1;
        unsigned	HTS                 : 1;
        unsigned	OSTS                : 1;
        unsigned	IRCF                : 3;
    struct {
        unsigned	                    : 4;
        unsigned	IRCF0               : 1;
        unsigned	IRCF1               : 1;
        unsigned	IRCF2               : 1;
} OSCCONbits @ 0x08F;
#endif
// Register: OSCTUNE
volatile unsigned char           OSCTUNE             @ 0x090;
volatile bit TUN0                @ ((unsigned)&OSCTUNE*8)+0;
volatile bit TUN1                @ ((unsigned)&OSCTUNE*8)+1;
volatile bit TUN2                @ ((unsigned)&OSCTUNE*8)+2;
volatile bit TUN3                @ ((unsigned)&OSCTUNE*8)+3;
volatile bit TUN4                @ ((unsigned)&OSCTUNE*8)+4;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TUN                 : 5;
    struct {
        unsigned	TUN0                : 1;
        unsigned	TUN1                : 1;
        unsigned	TUN2                : 1;
        unsigned	TUN3                : 1;
        unsigned	TUN4                : 1;
} OSCTUNEbits @ 0x090;
#endif
// Register: PR2
volatile unsigned char           PR2                 @ 0x092;
// Register: SSPADD
volatile unsigned char           SSPADD              @ 0x093;
// Register: SSPMSK
volatile unsigned char           SSPMSK              @ 0x093;	// shared address with SSPADD
volatile unsigned char           MSK                 @ 0x093;	// shared address with SSPADD
volatile bit MSK0                @ ((unsigned)&SSPMSK*8)+0;
volatile bit MSK1                @ ((unsigned)&SSPMSK*8)+1;
volatile bit MSK2                @ ((unsigned)&SSPMSK*8)+2;
volatile bit MSK3                @ ((unsigned)&SSPMSK*8)+3;
volatile bit MSK4                @ ((unsigned)&SSPMSK*8)+4;
volatile bit MSK5                @ ((unsigned)&SSPMSK*8)+5;
volatile bit MSK6                @ ((unsigned)&SSPMSK*8)+6;
volatile bit MSK7                @ ((unsigned)&SSPMSK*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	MSK0                : 1;
        unsigned	MSK1                : 1;
        unsigned	MSK2                : 1;
        unsigned	MSK3                : 1;
        unsigned	MSK4                : 1;
        unsigned	MSK5                : 1;
        unsigned	MSK6                : 1;
        unsigned	MSK7                : 1;
} SSPMSKbits @ 0x093;
#endif
// Register: SSPSTAT
volatile unsigned char           SSPSTAT             @ 0x094;
volatile bit BF                  @ ((unsigned)&SSPSTAT*8)+0;
volatile bit UA                  @ ((unsigned)&SSPSTAT*8)+1;
volatile bit R_nW                @ ((unsigned)&SSPSTAT*8)+2;
volatile bit S                   @ ((unsigned)&SSPSTAT*8)+3;
volatile bit P                   @ ((unsigned)&SSPSTAT*8)+4;
volatile bit D_nA                @ ((unsigned)&SSPSTAT*8)+5;
volatile bit CKE                 @ ((unsigned)&SSPSTAT*8)+6;
volatile bit SMP                 @ ((unsigned)&SSPSTAT*8)+7;
volatile bit R                   @ ((unsigned)&SSPSTAT*8)+2;
volatile bit D                   @ ((unsigned)&SSPSTAT*8)+5;
volatile bit I2C_READ            @ ((unsigned)&SSPSTAT*8)+2;
volatile bit I2C_START           @ ((unsigned)&SSPSTAT*8)+3;
volatile bit I2C_STOP            @ ((unsigned)&SSPSTAT*8)+4;
volatile bit I2C_DATA            @ ((unsigned)&SSPSTAT*8)+5;
volatile bit nW                  @ ((unsigned)&SSPSTAT*8)+2;
volatile bit nA                  @ ((unsigned)&SSPSTAT*8)+5;
volatile bit nWRITE              @ ((unsigned)&SSPSTAT*8)+2;
volatile bit nADDRESS            @ ((unsigned)&SSPSTAT*8)+5;
volatile bit R_W                 @ ((unsigned)&SSPSTAT*8)+2;
volatile bit D_A                 @ ((unsigned)&SSPSTAT*8)+5;
volatile bit READ_WRITE          @ ((unsigned)&SSPSTAT*8)+2;
volatile bit DATA_ADDRESS        @ ((unsigned)&SSPSTAT*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	BF                  : 1;
        unsigned	UA                  : 1;
        unsigned	R_nW                : 1;
        unsigned	S                   : 1;
        unsigned	P                   : 1;
        unsigned	D_nA                : 1;
        unsigned	CKE                 : 1;
        unsigned	SMP                 : 1;
    struct {
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
    struct {
        unsigned	                    : 2;
        unsigned	R                   : 1;
        unsigned	: 2;
        unsigned	D                   : 1;
    struct {
        unsigned	: 2;
        unsigned	I2C_READ            : 1;
        unsigned	I2C_START           : 1;
        unsigned	I2C_STOP            : 1;
        unsigned	I2C_DATA            : 1;
    struct {
        unsigned	: 2;
        unsigned	nW                  : 1;
        unsigned	: 2;
        unsigned	nA                  : 1;
    struct {
        unsigned	: 2;
        unsigned	nWRITE              : 1;
        unsigned	: 2;
        unsigned	nADDRESS            : 1;
    struct {
        unsigned	: 2;
        unsigned	R_W                 : 1;
        unsigned	: 2;
        unsigned	D_A                 : 1;
    struct {
        unsigned	: 2;
        unsigned	READ_WRITE          : 1;
        unsigned	: 2;
        unsigned	DATA_ADDRESS        : 1;
} SSPSTATbits @ 0x094;
#endif
// Register: WPUA
volatile unsigned char           WPUA                @ 0x095;
volatile unsigned char           WPU                 @ 0x095;
volatile bit WPUA0               @ ((unsigned)&WPUA*8)+0;
volatile bit WPUA1               @ ((unsigned)&WPUA*8)+1;
volatile bit WPUA2               @ ((unsigned)&WPUA*8)+2;
volatile bit WPUA4               @ ((unsigned)&WPUA*8)+4;
volatile bit WPUA5               @ ((unsigned)&WPUA*8)+5;
volatile bit WPU0                @ ((unsigned)&WPUA*8)+0;
volatile bit WPU1                @ ((unsigned)&WPUA*8)+1;
volatile bit WPU2                @ ((unsigned)&WPUA*8)+2;
volatile bit WPU4                @ ((unsigned)&WPUA*8)+4;
volatile bit WPU5                @ ((unsigned)&WPUA*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	WPUA0               : 1;
        unsigned	WPUA1               : 1;
        unsigned	WPUA2               : 1;
        unsigned	                    : 1;
        unsigned	WPUA4               : 1;
        unsigned	WPUA5               : 1;
    struct {
        unsigned	WPU0                : 1;
        unsigned	WPU1                : 1;
        unsigned	WPU2                : 1;
        unsigned	: 1;
        unsigned	WPU4                : 1;
        unsigned	WPU5                : 1;
} WPUAbits @ 0x095;
#endif
// Register: IOCA
volatile unsigned char           IOCA                @ 0x096;
volatile unsigned char           IOC                 @ 0x096;
volatile bit IOCA0               @ ((unsigned)&IOCA*8)+0;
volatile bit IOCA1               @ ((unsigned)&IOCA*8)+1;
volatile bit IOCA2               @ ((unsigned)&IOCA*8)+2;
volatile bit IOCA3               @ ((unsigned)&IOCA*8)+3;
volatile bit IOCA4               @ ((unsigned)&IOCA*8)+4;
volatile bit IOCA5               @ ((unsigned)&IOCA*8)+5;
volatile bit IOC0                @ ((unsigned)&IOCA*8)+0;
volatile bit IOC1                @ ((unsigned)&IOCA*8)+1;
volatile bit IOC2                @ ((unsigned)&IOCA*8)+2;
volatile bit IOC3                @ ((unsigned)&IOCA*8)+3;
volatile bit IOC4                @ ((unsigned)&IOCA*8)+4;
volatile bit IOC5                @ ((unsigned)&IOCA*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	IOCA0               : 1;
        unsigned	IOCA1               : 1;
        unsigned	IOCA2               : 1;
        unsigned	IOCA3               : 1;
        unsigned	IOCA4               : 1;
        unsigned	IOCA5               : 1;
    struct {
        unsigned	IOC0                : 1;
        unsigned	IOC1                : 1;
        unsigned	IOC2                : 1;
        unsigned	IOC3                : 1;
        unsigned	IOC4                : 1;
        unsigned	IOC5                : 1;
} IOCAbits @ 0x096;
#endif
// Register: WDTCON
volatile unsigned char           WDTCON              @ 0x097;
volatile bit SWDTEN              @ ((unsigned)&WDTCON*8)+0;
volatile bit WDTPS0              @ ((unsigned)&WDTCON*8)+1;
volatile bit WDTPS1              @ ((unsigned)&WDTCON*8)+2;
volatile bit WDTPS2              @ ((unsigned)&WDTCON*8)+3;
volatile bit WDTPS3              @ ((unsigned)&WDTCON*8)+4;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	SWDTEN              : 1;
        unsigned	WDTPS               : 4;
    struct {
        unsigned	                    : 1;
        unsigned	WDTPS0              : 1;
        unsigned	WDTPS1              : 1;
        unsigned	WDTPS2              : 1;
        unsigned	WDTPS3              : 1;
} WDTCONbits @ 0x097;
#endif
// Register: TXSTA
volatile unsigned char           TXSTA               @ 0x098;
volatile bit TX9D                @ ((unsigned)&TXSTA*8)+0;
volatile bit TRMT                @ ((unsigned)&TXSTA*8)+1;
volatile bit BRGH                @ ((unsigned)&TXSTA*8)+2;
volatile bit SENDB               @ ((unsigned)&TXSTA*8)+3;
volatile bit SYNC                @ ((unsigned)&TXSTA*8)+4;
volatile bit TXEN                @ ((unsigned)&TXSTA*8)+5;
volatile bit TX9                 @ ((unsigned)&TXSTA*8)+6;
volatile bit CSRC                @ ((unsigned)&TXSTA*8)+7;
volatile bit SENB                @ ((unsigned)&TXSTA*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TX9D                : 1;
        unsigned	TRMT                : 1;
        unsigned	BRGH                : 1;
        unsigned	SENDB               : 1;
        unsigned	SYNC                : 1;
        unsigned	TXEN                : 1;
        unsigned	TX9                 : 1;
        unsigned	CSRC                : 1;
    struct {
        unsigned	                    : 3;
        unsigned	SENB                : 1;
} TXSTAbits @ 0x098;
#endif
// Register: SPBRG
volatile unsigned char           SPBRG               @ 0x099;
volatile bit BRG0                @ ((unsigned)&SPBRG*8)+0;
volatile bit BRG1                @ ((unsigned)&SPBRG*8)+1;
volatile bit BRG2                @ ((unsigned)&SPBRG*8)+2;
volatile bit BRG3                @ ((unsigned)&SPBRG*8)+3;
volatile bit BRG4                @ ((unsigned)&SPBRG*8)+4;
volatile bit BRG5                @ ((unsigned)&SPBRG*8)+5;
volatile bit BRG6                @ ((unsigned)&SPBRG*8)+6;
volatile bit BRG7                @ ((unsigned)&SPBRG*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	BRG0                : 1;
        unsigned	BRG1                : 1;
        unsigned	BRG2                : 1;
        unsigned	BRG3                : 1;
        unsigned	BRG4                : 1;
        unsigned	BRG5                : 1;
        unsigned	BRG6                : 1;
        unsigned	BRG7                : 1;
} SPBRGbits @ 0x099;
#endif
// Register: SPBRGH
volatile unsigned char           SPBRGH              @ 0x09A;
volatile bit BRG8                @ ((unsigned)&SPBRGH*8)+0;
volatile bit BRG9                @ ((unsigned)&SPBRGH*8)+1;
volatile bit BRG10               @ ((unsigned)&SPBRGH*8)+2;
volatile bit BRG11               @ ((unsigned)&SPBRGH*8)+3;
volatile bit BRG12               @ ((unsigned)&SPBRGH*8)+4;
volatile bit BRG13               @ ((unsigned)&SPBRGH*8)+5;
volatile bit BRG14               @ ((unsigned)&SPBRGH*8)+6;
volatile bit BRG15               @ ((unsigned)&SPBRGH*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	BRG8                : 1;
        unsigned	BRG9                : 1;
        unsigned	BRG10               : 1;
        unsigned	BRG11               : 1;
        unsigned	BRG12               : 1;
        unsigned	BRG13               : 1;
        unsigned	BRG14               : 1;
        unsigned	BRG15               : 1;
} SPBRGHbits @ 0x09A;
#endif
// Register: BAUDCTL
volatile unsigned char           BAUDCTL             @ 0x09B;
volatile bit ABDEN               @ ((unsigned)&BAUDCTL*8)+0;
volatile bit WUE                 @ ((unsigned)&BAUDCTL*8)+1;
volatile bit BRG16               @ ((unsigned)&BAUDCTL*8)+3;
volatile bit SCKP                @ ((unsigned)&BAUDCTL*8)+4;
volatile bit RCIDL               @ ((unsigned)&BAUDCTL*8)+6;
volatile bit ABDOVF              @ ((unsigned)&BAUDCTL*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	ABDEN               : 1;
        unsigned	WUE                 : 1;
        unsigned	                    : 1;
        unsigned	BRG16               : 1;
        unsigned	SCKP                : 1;
        unsigned	: 1;
        unsigned	RCIDL               : 1;
        unsigned	ABDOVF              : 1;
} BAUDCTLbits @ 0x09B;
#endif
// Register: ADRESL
volatile unsigned char           ADRESL              @ 0x09E;
// Register: ADCON1
volatile unsigned char           ADCON1              @ 0x09F;
volatile bit ADCS0               @ ((unsigned)&ADCON1*8)+4;
volatile bit ADCS1               @ ((unsigned)&ADCON1*8)+5;
volatile bit ADCS2               @ ((unsigned)&ADCON1*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 4;
        unsigned	ADCS                : 3;
    struct {
        unsigned	: 4;
        unsigned	ADCS0               : 1;
        unsigned	ADCS1               : 1;
        unsigned	ADCS2               : 1;
} ADCON1bits @ 0x09F;
#endif
// Special function register definitions: Bank 2
// Register: EEDAT
volatile unsigned char           EEDAT               @ 0x10C;
volatile unsigned char           EEDATA              @ 0x10C;
// Register: EEADR
volatile unsigned char           EEADR               @ 0x10D;
// Register: EEDATH
volatile unsigned char           EEDATH              @ 0x10E;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 6;
} EEDATHbits @ 0x10E;
#endif
// Register: EEADRH
volatile unsigned char           EEADRH              @ 0x10F;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 4;
} EEADRHbits @ 0x10F;
#endif
// Register: WPUB
volatile unsigned char           WPUB                @ 0x115;
volatile bit WPUB4               @ ((unsigned)&WPUB*8)+4;
volatile bit WPUB5               @ ((unsigned)&WPUB*8)+5;
volatile bit WPUB6               @ ((unsigned)&WPUB*8)+6;
volatile bit WPUB7               @ ((unsigned)&WPUB*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 4;
        unsigned	WPUB                : 4;
    struct {
        unsigned	: 4;
        unsigned	WPUB4               : 1;
        unsigned	WPUB5               : 1;
        unsigned	WPUB6               : 1;
        unsigned	WPUB7               : 1;
} WPUBbits @ 0x115;
#endif
// Register: IOCB
volatile unsigned char           IOCB                @ 0x116;
volatile bit IOCB4               @ ((unsigned)&IOCB*8)+4;
volatile bit IOCB5               @ ((unsigned)&IOCB*8)+5;
volatile bit IOCB6               @ ((unsigned)&IOCB*8)+6;
volatile bit IOCB7               @ ((unsigned)&IOCB*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 4;
        unsigned	IOCB4               : 1;
        unsigned	IOCB5               : 1;
        unsigned	IOCB6               : 1;
        unsigned	IOCB7               : 1;
} IOCBbits @ 0x116;
#endif
// Register: VRCON
volatile unsigned char           VRCON               @ 0x118;
volatile bit VP6EN               @ ((unsigned)&VRCON*8)+4;
volatile bit VRR                 @ ((unsigned)&VRCON*8)+5;
volatile bit C2VREN              @ ((unsigned)&VRCON*8)+6;
volatile bit C1VREN              @ ((unsigned)&VRCON*8)+7;
volatile bit VR0                 @ ((unsigned)&VRCON*8)+0;
volatile bit VR1                 @ ((unsigned)&VRCON*8)+1;
volatile bit VR2                 @ ((unsigned)&VRCON*8)+2;
volatile bit VR3                 @ ((unsigned)&VRCON*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	VR                  : 4;
        unsigned	VP6EN               : 1;
        unsigned	VRR                 : 1;
        unsigned	C2VREN              : 1;
        unsigned	C1VREN              : 1;
    struct {
        unsigned	VR0                 : 1;
        unsigned	VR1                 : 1;
        unsigned	VR2                 : 1;
        unsigned	VR3                 : 1;
} VRCONbits @ 0x118;
#endif
// Register: CM1CON0
volatile unsigned char           CM1CON0             @ 0x119;
volatile bit C1R                 @ ((unsigned)&CM1CON0*8)+2;
volatile bit C1POL               @ ((unsigned)&CM1CON0*8)+4;
volatile bit C1OE                @ ((unsigned)&CM1CON0*8)+5;
volatile bit C1OUT               @ ((unsigned)&CM1CON0*8)+6;
volatile bit C1ON                @ ((unsigned)&CM1CON0*8)+7;
volatile bit C1CH0               @ ((unsigned)&CM1CON0*8)+0;
volatile bit C1CH1               @ ((unsigned)&CM1CON0*8)+1;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	C1CH                : 2;
        unsigned	C1R                 : 1;
        unsigned	                    : 1;
        unsigned	C1POL               : 1;
        unsigned	C1OE                : 1;
        unsigned	C1OUT               : 1;
        unsigned	C1ON                : 1;
    struct {
        unsigned	C1CH0               : 1;
        unsigned	C1CH1               : 1;
} CM1CON0bits @ 0x119;
#endif
// Register: CM2CON0
volatile unsigned char           CM2CON0             @ 0x11A;
volatile bit C2R                 @ ((unsigned)&CM2CON0*8)+2;
volatile bit C2POL               @ ((unsigned)&CM2CON0*8)+4;
volatile bit C2OE                @ ((unsigned)&CM2CON0*8)+5;
volatile bit C2OUT               @ ((unsigned)&CM2CON0*8)+6;
volatile bit C2ON                @ ((unsigned)&CM2CON0*8)+7;
volatile bit C2CH0               @ ((unsigned)&CM2CON0*8)+0;
volatile bit C2CH1               @ ((unsigned)&CM2CON0*8)+1;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	C2CH                : 2;
        unsigned	C2R                 : 1;
        unsigned	                    : 1;
        unsigned	C2POL               : 1;
        unsigned	C2OE                : 1;
        unsigned	C2OUT               : 1;
        unsigned	C2ON                : 1;
    struct {
        unsigned	C2CH0               : 1;
        unsigned	C2CH1               : 1;
} CM2CON0bits @ 0x11A;
#endif
// Register: CM2CON1
volatile unsigned char           CM2CON1             @ 0x11B;
volatile bit C2SYNC              @ ((unsigned)&CM2CON1*8)+0;
volatile bit T1GSS               @ ((unsigned)&CM2CON1*8)+1;
volatile bit MC2OUT              @ ((unsigned)&CM2CON1*8)+6;
volatile bit MC1OUT              @ ((unsigned)&CM2CON1*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	C2SYNC              : 1;
        unsigned	T1GSS               : 1;
        unsigned	                    : 4;
        unsigned	MC2OUT              : 1;
        unsigned	MC1OUT              : 1;
} CM2CON1bits @ 0x11B;
#endif
// Register: ANSEL
volatile unsigned char           ANSEL               @ 0x11E;
volatile bit ANS0                @ ((unsigned)&ANSEL*8)+0;
volatile bit ANS1                @ ((unsigned)&ANSEL*8)+1;
volatile bit ANS2                @ ((unsigned)&ANSEL*8)+2;
volatile bit ANS3                @ ((unsigned)&ANSEL*8)+3;
volatile bit ANS4                @ ((unsigned)&ANSEL*8)+4;
volatile bit ANS5                @ ((unsigned)&ANSEL*8)+5;
volatile bit ANS6                @ ((unsigned)&ANSEL*8)+6;
volatile bit ANS7                @ ((unsigned)&ANSEL*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	ANS0                : 1;
        unsigned	ANS1                : 1;
        unsigned	ANS2                : 1;
        unsigned	ANS3                : 1;
        unsigned	ANS4                : 1;
        unsigned	ANS5                : 1;
        unsigned	ANS6                : 1;
        unsigned	ANS7                : 1;
} ANSELbits @ 0x11E;
#endif
// Register: ANSELH
volatile unsigned char           ANSELH              @ 0x11F;
volatile bit ANS8                @ ((unsigned)&ANSELH*8)+0;
volatile bit ANS9                @ ((unsigned)&ANSELH*8)+1;
volatile bit ANS10               @ ((unsigned)&ANSELH*8)+2;
volatile bit ANS11               @ ((unsigned)&ANSELH*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	ANS8                : 1;
        unsigned	ANS9                : 1;
        unsigned	ANS10               : 1;
        unsigned	ANS11               : 1;
} ANSELHbits @ 0x11F;
#endif
// Special function register definitions: Bank 3
// Register: EECON1
volatile unsigned char           EECON1              @ 0x18C;
volatile bit RD                  @ ((unsigned)&EECON1*8)+0;
volatile bit WR                  @ ((unsigned)&EECON1*8)+1;
volatile bit WREN                @ ((unsigned)&EECON1*8)+2;
volatile bit WRERR               @ ((unsigned)&EECON1*8)+3;
volatile bit EEPGD               @ ((unsigned)&EECON1*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RD                  : 1;
        unsigned	WR                  : 1;
        unsigned	WREN                : 1;
        unsigned	WRERR               : 1;
        unsigned	                    : 3;
        unsigned	EEPGD               : 1;
} EECON1bits @ 0x18C;
#endif
// Register: EECON2
volatile unsigned char           EECON2              @ 0x18D;
// Register: PSTRCON
volatile unsigned char           PSTRCON             @ 0x19D;
volatile bit STRA                @ ((unsigned)&PSTRCON*8)+0;
volatile bit STRB                @ ((unsigned)&PSTRCON*8)+1;
volatile bit STRC                @ ((unsigned)&PSTRCON*8)+2;
volatile bit STRD                @ ((unsigned)&PSTRCON*8)+3;
volatile bit STRSYNC             @ ((unsigned)&PSTRCON*8)+4;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	STRA                : 1;
        unsigned	STRB                : 1;
        unsigned	STRC                : 1;
        unsigned	STRD                : 1;
        unsigned	STRSYNC             : 1;
} PSTRCONbits @ 0x19D;
#endif
// Register: SRCON
volatile unsigned char           SRCON               @ 0x19E;
volatile bit PULSR               @ ((unsigned)&SRCON*8)+2;
volatile bit PULSS               @ ((unsigned)&SRCON*8)+3;
volatile bit C2REN               @ ((unsigned)&SRCON*8)+4;
volatile bit C1SEN               @ ((unsigned)&SRCON*8)+5;
volatile bit SR0                 @ ((unsigned)&SRCON*8)+6;
volatile bit SR1                 @ ((unsigned)&SRCON*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 2;
        unsigned	PULSR               : 1;
        unsigned	PULSS               : 1;
        unsigned	C2REN               : 1;
        unsigned	C1SEN               : 1;
        unsigned	SR                  : 2;
    struct {
        unsigned	: 6;
        unsigned	SR0                 : 1;
        unsigned	SR1                 : 1;
} SRCONbits @ 0x19E;
#endif
#endif
The following modified code compiles without error using Hi-Tech Compiler v9.83
        //  Version      : 1.0
        //  Compiler     : HITECT PICC-Lite Version 9.83
        //  IDE          : Microchip MPLAB IDE v8.70
        #include <htc.h>
        __CONFIG(FOSC_INTRCIO & WDTE_OFF & PWRTE_ON & MCLRE_ON & CP_OFF & CPD_OFF & BOREN_OFF & IESO_OFF & FCMEN_OFF);
              pulse_max=0;
              pulse_top=0;
        void main(void)
          int ldr_diff;
          pulse_max=0;
          pulse_top=0;
          /* Initial ADC */
          OPTION_REG = 0b00000000; // 1:2 Prescaller
          for(;;) {
            GO_DONE=1;                // initiate conversion on the channel 4
            while(GO_DONE) continue;  // Wait for ldr_left conversion done
            GO_DONE=1;                // initiate conversion on the channel 5
            while(GO_DONE) continue;  // Wait for ldr_right conversion done
            } else {
              } else {
        /* EOF: servo.c */
Build Log/Report
Build C:\Documents and Settings\Administrator.BDG\My Documents\Projects\EDAboard\pradeep_k_b\pradeep_k_b for device 16F690
Using driver C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe
Make: The target "C:\Documents and Settings\Administrator.BDG\My Documents\Projects\EDAboard\pradeep_k_b\main.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 "C:\Documents and Settings\Administrator.BDG\My Documents\Projects\EDAboard\pradeep_k_b\main.c" -q --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 --rom=default --ram=default -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" -opradeep_k_b.cof -mpradeep_k_b.map --summary=default --output=default main.p1 --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 --rom=default --ram=default -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
HI-TECH C Compiler for PIC10/12/16 MCUs (PRO Mode) V9.83
Copyright (C) 2011 Microchip Technology Inc.
Serial number: HCPICP-XXXXXXXXX (PRO)
Memory Summary:
Program space used 88h ( 136) of 1000h words ( 3.3%)
Data space used Bh ( 11) of 100h bytes ( 4.3%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Configuration bits used 1h ( 1) of 1h word (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Loaded C:\Documents and Settings\Administrator.BDG\My Documents\Projects\EDAboard\pradeep_k_b\pradeep_k_b.cof.
********** Build successful! **********
BigDog
hi..thank u...just now i tried the new prgramm with MPLAB IDE..then got an error message like
"Build C:\Users\PRAMOD\Desktop\DElete it\hi for device 16F690
Using driver C:\Program Files\HI-TECH Software\PICC\LITE\9.60\bin\picl.exe
Executing: "C:\Program Files\HI-TECH Software\PICC\LITE\9.60\bin\picl.exe" -ohi.cof -mhi.map --summary=default --output=default --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
HI-TECH PICC-Lite COMPILER (Microchip PICmicro) V9.60PL1
Copyright (C) 1984-2007 HI-TECH SOFTWARE
Error [939] ; . no file arguments
********** Build failed! **********
then i did an attempt with mikroC pro,then got another error message "0 1 mikroCPIC1618.exe -MSF -DBG -pP16F690 -DL -O11111114 -fo8 -N"C:\Users\PRAMOD\Desktop\DElete it\new.mcppi" -SP"C:\Users\Public\Documents\Mikroelektronika\mikroC PRO for PIC\defs\" -SP"C:\Users\Public\Documents\Mikroelektronika\mikroC PRO for PIC\Uses\P16\" -SP"C:\Users\PRAMOD\Desktop\DElete it\" "new.c" "hamming_test.c" "__Lib_Math.mcl" "__Lib_MathDouble.mcl" "__Lib_System.mcl" "__Lib_Delays.mcl" "__Lib_CType.mcl" "__Lib_CString.mcl" "__Lib_CStdlib.mcl" "__Lib_CMath.mcl" "__Lib_Conversions.mcl" "__Lib_Sprinti.mcl" "__Lib_Sprintl.mcl" "__Lib_Time.mcl" "__Lib_Trigonometry.mcl" "__Lib_Button.mcl" "__Lib_Keypad4x4.mcl" "__Lib_Manchester.mcl" "__Lib_OneWire.mcl" "__Lib_PS2.mcl" "__Lib_Sound.mcl" "__Lib_SoftI2C.mcl" "__Lib_SoftSPI.mcl" "__Lib_SoftUART.mcl" "__Lib_ADC_A_B.mcl" "__Lib_EEPROM.mcl" "__Lib_FLASH_R.mcl" "__Lib_PWM_c5.mcl" "__Lib_SPI_b64c7.mcl" "__Lib_UART_b75.mcl" "__Lib_PortExpander.mcl" "__Lib_CANSPI.mcl" "__Lib_GlcdFonts.mcl" "__Lib_Glcd.mcl" "__Lib_LcdConsts.mcl" "__Lib_Lcd.mcl" "__Lib_RS485.mcl" "__Lib_S1D13700.mcl" "__Lib_SPIGlcd.mcl" "__Lib_SPILcd.mcl" "__Lib_SPILcd8.mcl" "__Lib_SPIT6963C.mcl" "__Lib_EthEnc28j60.mcl" "__Lib_TFT.mcl" "__Lib_TouchPanel_TFT.mcl" "__Lib_EthEnc24j600.mcl" "__Lib_TouchPanel.mcl"
0 1139 Available RAM: 240 [bytes], Available ROM: 4096 [bytes]
0 304 C:/Users/PRAMOD/Desktop/DElete it/new.c:10: error: Can't open include file "htc.h"
0 304 #include <htc.h>
0 304 1 error in preprocessor.
0 304 C:/Users/PRAMOD/Desktop/DElete it/hamming_test.c:10: error: Can't open include file "htc.h"
0 102 Finished (with errors): 15 Jun 2012, 09:02:12 new.mcppi
I am less experienced with this pic programming....:(...
First, I would recommend upgrading the Hi-Tech Compiler to the latest version:
The version you are currently using is quite old, v9.60. Download load the latest version from the link above and install.
Second, You need to add the C file to the Project by right clicking in the Project Window on "Source Files" Directory and select "Add Files..."
Then rebuild the project.
BigDog
sir,,,I dont have a standard PIC programmer,,,my PIC programmer is a locally available one....i think thats the problem...MPLAB IDE is not ready to support my device
the link shows the programmer that im using now
Let's take care of one issue at a time.
Have you successfully compiled the code with the current version of the Hi-Tech Compiler?
Your choice of programmer does not effect on the compiling of the code.
The HEX file created by the Hi-Tech Compiler is a standard format (Intel HEX) compatible with most programmers including yours.
BigDog
no..:(...i got a new error message
Build C:\Users\PRAMOD\Desktop\DElete it\helo for device 16F690
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" -ohelo.cof -mhelo.map --summary=default --output=default --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Licensed for evaluation purposes only.
This licence will expire on Sat, 04 Aug 2012.
Have you used the Project Wizard to build the project file?
If not, do so. When asked if you want to include any files, include the C file with the modified code I have provided.
I have attached a working zipped directory with C source, Project and Workspace File. Open the project file and build.
BigDog
  • pradeep_k_bv2.zip
thank u sir.....was successful
Build C:\Users\PRAMOD\Desktop\DElete it\hello2\my first for device 16F690
Make: The target "C:\Users\PRAMOD\Desktop\DElete it\hello2\hai.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 "C:\Users\PRAMOD\Desktop\DElete it\hello2\hai.c" -q --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Executing: "C:\Program Files\HI-TECH Software\PICC\9.83\bin\picc.exe" "-omy first.cof" "-mmy first.map" --summary=default --output=default hai.p1 --chip=16F690 -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Memory Summary:
Loaded C:\Users\PRAMOD\Desktop\DElete it\hello2\my first.cof.
...thank u
sir..but the code is only 1KB..???...
I'm glad to here it.
At least now you know how to setup a project and compile it.
Now you need to startup the software for your programmer and load the file:
my_first.hex
And then program your pic.
BigDog
How large did you expect it to be?
The PIC16F690 only has a 7 kilobytes (4k of program words) of flash by which to store the program.
BigDog
ok sir...thank u....btw if i want to convert a .asm file to hex,then is it required to use another compiler????.....i have the same problem with the asm files too..
An assembler is used to convert Assembly Code to a HEX file.
The MPLAB comes with an Assembler, MPASM.
Start a new project using the Project Wizard and select Microchip MPASM Toolsuite, instead of the Hi-Tech Compiler.
BigDog
done...but the result was....
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\htre.mcp' started.
Preprocessor symbol `__DEBUG' is defined.
Fri Jun 15 12:17:08 2012
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Users\PRAMOD\Desktop\important\delete\htre.mcs".
Clean: Done.
Executing: "C:\Program Files\HI-TECH Software\PICC\LITE\9.60\bin\picl.exe" /q /p16F628A "enc-044.asm" /l"enc-044.lst" /e"enc-044.err" /d__DEBUG=1
(902) no chip name specified; use "PICC --CHIPINFO" to see available chip names
Halting build on first failure as requested.
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\htre.mcp' failed.
BUILD FAILED
According to the Build Log the project is still attempting to use the Hi-Tech C Compiler rather than the Assembler MPASM.
Did you close the previous project and then use the Project Wizard to start a new project selecting the Microchip MPASM Toolsuite and the PIC16F690 as the device?
Please post your Assembly Code, ASM file, using CODE Tags.
BigDog
;    Filename:	    encoder.asm                                       *
;    Date:                                                            *
;    File Version:                                                    *
;NOTES
;encoder v4.2
;HISTORY
; 040-20050131 4/8-channel encoder for 16F630
; 041-20050213
; 042-20050217 modify transmission repetition algorithm
; 043-20050227 use IR medium with irmtxv4 library
; 044-20090531 adapt 042-20050227 to the pic16f628
	list	p=16f628
	__CONFIG   _CP_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _MCLRE_OFF & _BODEN_OFF
; toggle or momentary mode, 8 channels
#define MODE_CH8
; ON/OFF latched mode, 4 channels
;#define MODE_CH4
#include <p16F628.inc>
#include <mtxv4.inc>
variables	UDATA
; RAM registers
tcnt		RES 1
rcnt		RES 1
cod		RES 1
prevcod		RES 1
cod0		RES 1
rowstate	RES 1
startup		CODE 0
  		goto main
		nop
		nop
		nop
		retfie
prog		CODE
main		; program starts here
		clrf PORTA
		clrf PORTB
		clrf TMR0
		BANKSEL TRISA
		movlw 0
		movwf TRISA
		movlw 0xf0
		movwf TRISB
		bcf OPTION_REG, PSA
		clrwdt
		clrf OPTION_REG
		clrwdt
		BANKSEL PORTA
		movlw 7
		movwf CMCON
		movlw (1<<RBIE); RB4-7 int on change enable
		movwf INTCON
		call mtx_init
		clrf mtx_buffer
		clrf tcnt
loop0		clrf (mtx_buffer+1)
		movlw 0xff
		movwf prevcod ; no button was pressed in the previous scan
		movlw 0xfc ;ca,cb=0,cj=1
		movwf PORTB
		movlw 0xf0
		tris PORTB
		movf PORTB, W
		bcf INTCON, RBIF
		sleep
loop		clrf cod
		movlw 0xfe
		tris PORTB ; select colA (RB0)
		clrf PORTB
#ifdef MODE_CH8
		clrw
#endif
#ifdef MODE_CH4
		movlw 0x20
#endif
		call scan
		movlw 0xfd
		tris PORTB ; select colB (RB1)
#ifdef MODE_CH8
		movlw 0x04
#endif
#ifdef MODE_CH4
		movlw 0x30
#endif
		call scan
		movf cod, W
		bz loop2 ; if no buton is pressed, skip
		subwf prevcod, W ; if the same button is pressed, skip
		bz loop2
		movf cod, W
		movwf prevcod ; a new button is pressed - rcnt=3
		movwf (mtx_buffer+1)
		movlw 3
		movwf rcnt
		movlw 0x40 ; new button - new transmission
		addwf tcnt, F
loop2		movlw 0xf7
		tris PORTB ; select ID (RB3)
		call scanid
		movf cod0, W
		movwf (mtx_buffer)
loop3		movf (mtx_buffer+1), W
		andlw 0x3f
		iorwf tcnt, W
		call mtx_send
		movf rcnt, W
		bz loop_done
		decfsz rcnt, F
		goto loop
loop_done	movf cod, W
		btfsc STATUS, Z
		goto loop0 ; no button was pressed, go sleep
		; if the same button is being hold, repeat the transmission
		goto loop
scan		movwf cod0
		;movlw 0xc0
scandelay	;addlw 1
		;bnz scandelay
		movlw 0xf0
		andwf PORTB, W
		movwf rowstate
		incf cod0, F
		btfss rowstate, 4
		goto pressed
		incf cod0, F
		btfss rowstate, 5
		goto pressed
		incf cod0, F
		btfss rowstate, 6
		goto pressed
		incf cod0, F
		btfss rowstate, 7
		goto pressed
		retlw 0
pressed		movf cod0, W
		movwf cod
		return
scanid		clrf cod0
		clrw
scandelay2	addlw 1
		bnz scandelay2
		movlw 0xf0
		andwf PORTB, W
		movwf rowstate
		btfss rowstate, 7
		bsf cod0, 3
		btfss rowstate, 6
		bsf cod0, 2
		btfss rowstate, 5
		bsf cod0, 1
		btfss rowstate, 4
		bsf cod0, 0
		return
		end
sir..its the code.....i tried it with a new project...but still not working...
and its for PIC16f628.....i selected the device correctly....but no use
Can you post the build log with the error messages after you used the Project Wizard?
One issue I noticed is that an additional INC file is required:
Do you have the mtxv4.inc file? You will need to add it to the project as well.
Also there maybe legacy SFRs or Configuration Register Bitmasks used which need to be updated.
Look in the device specific INC file for the correct SFR and Bitmask defines.
BigDog
please go through the help option of the mplab ide thoroughly . it will give you all the details about how to use it ... please do some research on how to select different compiler in the ide . help files will help
ya..i added mtxv4.inc then i got this
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\hm.mcp' started.
Fri Jun 15 13:52:43 2012
Clean: Deleted file "C:\Users\PRAMOD\Desktop\important\delete\hm.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "enc-044.asm" /l"enc-044.lst" /e"enc-044.err" /d__DEBUG=1
Message[301] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\P16F628.INC 35 : MESSAGE: (Processor-header file mismatch. Verify selected processor.)
Error[105] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 32 : Cannot open file (Include File "mtxv4.inc" not found)
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 34 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 43 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 50 : Directive only allowed when generating an object file
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 59 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 61 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 63 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 65 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 74 : Symbol not previously defined (mtx_init)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 75 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 78 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 84 : Use of this instruction is not recommended.
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 91 : Use of this instruction is not recommended.
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 101 : Use of this instruction is not recommended.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 117 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 125 : Use of this instruction is not recommended.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 128 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 130 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 133 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\ENC-044.ASM 135 : Symbol not previously defined (mtx_send)
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\hm.mcp' failed.
Fri Jun 15 13:52:44 2012
BUILD FAILED
You've selected the PIC16F628A when using the project wizard, however the Assembly code specifies the P16F628.INC without the 'A'.
Which PIC do you actually have, PIC16F628 or PIC16F628A? If it is the PIC16F628A then change the Assembly Code in the following places (marked in red):
	list	p=16f628[COLOR="#FF0000"]a[/COLOR]
#define MODE_CH8
;#define MODE_CH4
#include <p16F628[COLOR="#FF0000"]A[/COLOR].inc>
You may need to change other parts of the code depending on the differences between the PIC16F628 and PIC16F628A.
Otherwise change the selected device under Configure->Select Device... to the PIC16F628 without the 'A'.
Most of the remaining errors are due to the following:
When you "added" the mtxv4.inc file is it now located in the same directory as the enc-044.asm?
Did you add it to the project window by right clicking and selecting "add file..."?
If you answered yes to both questions try removing the <> from around the file name:
#include  mtxv4.inc
Also make sure the actual file is spell the same as the include line above.
BigDog
hi sir....i have tried it as u said,but still its not working..got a message like
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\cat.mcp' started.
Fri Jun 15 17:21:21 2012
Clean: Deleted file "C:\Users\PRAMOD\Desktop\important\delete\cat.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628 "enc-044.asm" /l"enc-044.lst" /e"enc-044.err" /d__DEBUG=1
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\MTXV4.INC 14 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\MTXV4.INC 15 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 34 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 43 : Directive only allowed when generating an object file
Error[149] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 50 : Directive only allowed when generating an object file
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 59 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 61 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 63 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 65 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 74 : Symbol not previously defined (mtx_init)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 75 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 78 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 84 : Use of this instruction is not recommended.
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 91 : Use of this instruction is not recommended.
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 101 : Use of this instruction is not recommended.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 117 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 125 : Use of this instruction is not recommended.
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 128 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 130 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 133 : Symbol not previously defined (mtx_buffer)
Error[113] C:\USERS\PRAMOD\DESKTOP\IMPORTANT\8758\ENC-044.ASM 135 : Symbol not previously defined (mtx_send)
Debug build of project `C:\Users\PRAMOD\Desktop\important\delete\cat.mcp' failed.
Fri Jun 15 17:21:22 2012
BUILD FAILED
