Mukesh10
Junior Member level 2
Hello Everyone
i am trying to pass mutiple interface to a module but it showing some problem. can anyone help me
Here is the code :
Thanks in Advance
Here is the code :
module dut_top#(
parameter WB_ADDR_WIDTH = 16,
parameter WB_DATA_WIDTH = 32,
parameter SOC_BASE_ADDRESS = 'h0F00,
parameter MAX_BOUNDRY = 'h1000
( input clock , resetn, ahb_intf ahb_if0, ahb_if1, ahb_if2, ahb_if3);
// Wishbone interface: Output from AHB2WB bridge
wb_intf wb_if();
// Output from interconnect and input to AHB2WB bridge
ahb_intf ahb_if4(clock, resetn);
// Bus Interface connected with the IP
bus_intf bus_if0();
bus_intf bus_if1();
bus_intf bus_if2();
bus_intf bus_if3();
// Connect all output from master to the input of arbiter
ahb_arbiter arbiter(ahb_if0, ahb_if1, ahb_if2, ahb_if3, ahb_if4, clock , resetn);
// AHB Arbiter output connected to wishbone bridge
ahb2wb#(.AWIDTH(WB_ADDR_WIDTH),
.DWIDTH(WB_DATA_WIDTH)
BRIDGE( .adr_o(wb_if.wb_addr_i),
.dat_o(wb_if.wb_dat_i),
.dat_i(wb_if.wb_dat_o),
.ack_i(wb_if.wb_ack_o),
.cyc_o(wb_if.wb_cyc_i),
.we_o(wb_if.wb_we_i),
.stb_o(wb_if.wb_stb_i),
.hclk(clock),
.hresetn(resetn),
.haddr(ahb_if4.HADDR),
.htrans(ahb_if4.HTRANS),
.hwrite(ahb_if4.HWRITE),
.hsize(ahb_if4.HSIZE),
.hburst(ahb_if4.HBURST),
.hsel(1'b1), // Since one slave.. hsel is always 1.
.hwdata(ahb_if4.HWDATA),
.hrdata(ahb_if4.HRDATA),
.hresp(ahb_if4.HRESP),
.hready(ahb_if4.HREADY),
.clk_i(wb_if.clock),
.rst_i(wb_if.arst)
// Connect output of bridge to the input of decoder
wb_decoder #(.SOC_BASE_ADDRESS(SOC_BASE_ADDRESS),
.MAX_BOUNDRY(MAX_BOUNDRY)
) decoder
(wb_if, bus_if0, bus_if1, bus_if2, bus_if3);
ip_top ( bus_if0, spi_if, clock, resetn);
endmodule
Thanks in Advance
