can any one correct my code please?
Cutey
Member level 2
i programmed the fllowing code it is crrect but get wrong result
the fllowing code is shif multiplying
please if any one can tell me it get wrong result?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity MUL is
Port ( clk : in STD_LOGIC;
-- i:in integer:=1;
result : out STD_LOGIC_vector(15 downto 0);
m : in STD_LOGIC_vector(7 downto 0);
n : in STD_LOGIC_vector(7 downto 0);
start:in std_logic);
end MUL;
architecture Behavioral of MUL is
signal count:integer:= 0;
signal n1,m1:std_logic_vector(7 downto 0);
signal result1:std_logic_vector(15 downto 0);
begin
process(clk)
begin
m1<=m;
n1<=n;
--result<=result1;
if (rising_edge(clk))then
if( start = '1' )then
result<="0000000000000000";
count <=0;
else
if (count /= 8 )then
if (m1(0)='1')then
result<=result1+n;
end if ;
n1 <=n(6 downto 0) & '0';
m1 <='0'& m (7 downto 1);
count <=count+1;
end if ;
end if;
end if ;
end process ;
end Behavioral;
this make shift by concatinon
Look sharp. You are not shifting m1 and n1.
Yes, but you did not shift m1 or n1. You're overwriting m1 and n1 with the same value in each cycle,
because m and n never change.
I'm completely helpless, if you don't manage to read your own code exactly.
Consider, what you want to achieve and write the code respectively. You may
want to copy m and n on start='1' and shift m1 and n1 later on.
