Can a dual supply OP-Amp be used with a single supply.....
senthilnathan.rajesh
Junior Member level 3
Can anybody tell whether a dual supply op-amp be used with a single supply for signal Amplification (say for example Audio Signal)...? If so how will be the circuit configuration in Non-inverting Amplifier mode....?
Thanks in Advance
Re: Can a dual supply OP-Amp be used with a single supply...
Yes but you will have to add a DC offset to the inputs so that the input transistors will be active/saturation.
    V
What OpAmp you will use ?
There is some info from page 53
Hello
You can use an dual voltage opamp like this
You may need to add some modifications to the circuit.
You can also check this page out.
http://www.geocities.com/thetonegod/opamp/opamp.html
and
http://www.swarthmore.edu/NatSci/echeeve1/Ref/SingleSupply/SingleSupply.html
there's a single voltage to dual voltage converter and you should not to change the preamp circuits.
