antenna_abc
Member level 3
Hi, all. I am going to measure a circular-pol antenna, and have a question about the calibration. Where can I find some calibrated circular-pol standard antennas for calibration?
I found some dual-pol antenna, but it requires extra 90 degree coupler to generate circular-polarization. So I am thinking if the mismatching for coupler and antenna increases the uncertainty of measurements?
Or can I use standard linear-pol antenna, and make two-sets of measurements including the theta and phi fields magnitude and phase to calibrate the circular-pol antenna? If so, are there any references about that?
Thanks.
Thanks.
