bestvlsi
Junior Member level 1
Hi All,
I am designing a VCO block for PLL . I have few doubts
1. I am using 2 different types of MOS transistors
a. Normal MOS transistors N_18_MM ,and
b.RF MOS transistors N_L18W500_18_RF . Is is it ok to use two different types of MOS transistors in the design?
2. Also in the corner analysis I ve located the files corresponding lib file for N_18_MM but I am not able to find those for RF MOS transistors , although there are two libraries for RF , core_rf_v2d4 and io_rf_v2d3 ... among these two i think the first is the one corresponding to the RF MOS transistors N_L18W500_18_RF . Am I correct ? Pls do tell the model libraries name if you know.
Regards.
Regards.
