cadence rtl compiler related
surajsasidarn
hi
how to synthesis a vhdl code which has hierarchy with cadence rtl compiler , can any one provide me with a sample tcl file
thanks in advance
hai friend,
you can refer this pdf to write a tcl script for doing synyhesis
thank you.
  • Syn_Place_and_Rt_V2.pdf
The Below command works and gives the slack value of a timing path in ETS (Encounter Timing System). Can any one provide the equivalent command in RC?
get_attribute [report_timing -from paddr_ip[28] -to dl010lll02177/O1l0ll01164185l_reg[19]/D -collection] slack
Thanks,
Aravind
