siongboon
Advanced Member level 1
Simple to use cable connection tester for any type cable harness with any unique connectors.
Easy to setup using screw terminal connector plug.
Simply plug in, learn the cable connection and start testing your production cables.
This cable tester is able to generate the test report via the USB connection. Report can be displayed on a computer or on your mobile phone.
For more information, you can check out the product page for Cable Connection Tester CCT-01 at
http://www.cable-tester.com/tester-products/cable-connectivity-tester-cct-01/
