walters
Advanced Member level 2
Thanks Skyhigh
This is it:
The emitter resistor sets the lower limit where the output AC signal can swing. However with the use if a bypass capacitor, the lower limit is extended, thus giving the output signal a larger AC swing.
The emitter resistor in parallel with the capacitor = reactance
so its Frequency based:
The Bypass capacitor is a "Frequency Based" gain because of reactance on the emitter resistor so the AC swing getting bigger only at certain frequencys
and limited at others
This is it:
