mfacen
Hello everyone...
I have this temperature controller in my basement that I designed, its an NodeMCU board ( ESP8266 Wifi module ) that I program with the Arduino software. The controller has temperature probes and controls an inline duct fan similar to the one in this picture:
The fan is rated at 80 Watts / 120 V , its a brushless single pole motor.
The NodeMCU drives the fan using a SSR ( Solid State Relay ) and at the moment its either on or off.
I have been wanting to make the system better by adjusting the speed of the fan depending on the temperature as it is loud and most of the time it doesn't need to run full speed to lower the temperature, with the setup I have I was thinking about driving the fan on/off in a PWM way but with very slow period of maybe 1 second or so, I did some experiments and I'm able to reduce the speed of the fan by switching on/off the relay, the fan has a lot of inertia so it kinds of averages its speed depending on the duration of the bursts.
Finally my question: is running the inline duct fan in this manner going to damage it in any way ? I did a trial and it seemed to work fine for a day, I tested different PWM ratios ( 1/2 second ON and 1/2 second OFF gives me about 1/3 of the speed ruffly ).
I did a lot of searches trying to find out if this manner of controlling a motor is feasible but couldn't find any literature other that burst firing PWM's for heavy resistive heating elements.
Thanks for your time...
