Building memory design using design compiler
kmegamind
Junior Member level 1
Alexandria , Egypt.
I want to build a simple memory module in design compiler
How can I write the VHDL or Verilog code in order for the compiler to build the module using SRAM cells ?
Is there a tutorial or an open source code for a memory module than can be compiled to produce an actual design with SRAM cells ?
I have TSMC 0.18 um library files
