boy
Advanced Member level 1
+used +adf +avionics
as i know, ADF operates by using an circular array of directional antennas. It uses a diode detector for each element and compare the received power among all elements. The one with strongest power depict the direction. The array is a circular one. Since you are a pilot, you might have seen some of this array at the airport.
