davidbenjamindix
Junior Member level 1
i want to 'build' my own solenoid to control a drawer in my woodworking project. it is a walnut box with hidden drawers that contain homemade neodymium magnetic locks. one or more of the drawers i would like a homemade solenoid to control the drawer opening and closing. i have a 4 channel 12volt DC remote control system, and one of the channels i would like to operate the solenoid with. now the drawer will be small, and i plan on building it with some type of slide or bearing (so it slides easy), and the drawer probably won't eject from the box no more than 5 or 6 inches.
i already have thin magnetic wire (i can't remember...there are 3 sizes), and have build a small solenoid before using a plastic pen tube and a nail for the core. my question is, what is the best material i should be using for the tube (where the wire coils around), including the thickness of the tube, and diameter of the tube. i also need to know the cheapest type of core that i should be using. im assuming the core is going to be pretty light so it travels in and out easily?
i also have another concern about the coil direction. how many wraps do i need....1000? should i wrap only one direction, and work out some type of switch that can change the current direction? or should i wrap both directions, use an on switch to **** the core into the tube, and use a spring to return the core after the current is removed? i'll take any advice or criticism, because im still learning, and still very inexperienced with electricity. thanks for your time!
David Dix
---------- Post added at 05:01 ---------- Previous post was at 04:20 ----------
i was just told i should just buy one. so now my question is, (im going for low cost) what kind of 12v DC solenoid should i buy? i suppose i will need a 2 way, and probably push type (because the drawer is going to be pushed out of the box). also, should i go with continuous duty?
David Dix
