Bjtpower
Full Member level 5
But this circuit is depended on Rset resistance and it will not act a "true constant current source". Because when you call it as "Constant Current Source" it should provide a constant current independent from load resistance.
This is better approximation form Linear.
https://www.linear.com/product/LT3092
Does it provide constant current irrespective of load
say suppose
My RSET Voltage will be 0.25
Ref Voltage 0.25
Load varied from 1 ohm to 100 ohm..
does it takes the constant current over entire range of resistor
Regards
Marx
