Buck Average Current Mode Controller - Inductor Current vs Output Current
with2ls
Junior Member level 3
A standard dual loop average current mode buck converter uses the following control loop to regulate the output voltage:
My question is:
What if the buck converter's output current (measured post output capacitor) is used as the current loop input instead of the inductor current IL?
Obviously this is not how it is normally done, but the average inductor current is considered output current (total inductor current minus the high frequencies removed by the output capacitor), so I would assume this is acceptable.
I ask because I am using some old hardware, and I'm trying to get a feel for if a hardware change is required.
My question is:
That is fine in a way, as you say, the average of the inductor current, is the output current.....but the inductor current is better as it has not yet gone through the output cap.....so if you take it from output, then you have an LC in there, and the associated double pole of this, so your feedback loop will have to be slowed down somewhat.
Thanks for the response.
I decided to just measure the loop response with the same compensator coefficients both ways and they are plotted below (Blue - Inductor Current, Orange - Output Current).
Does this explain the plot differences? I don't see a double pole anywhere and it looks like the gain difference could be adjusted without affecting the phase, which makes me think I am missing something (or measuring it incorrectly).
I guess the blue line (maye orange, too) is RMS current, thus just includes the ripple current.
--> use "average current" on both.
(The regulation loop can not compute "RMS" at all)
Again: just a guess
Does your voltage loop have an "inner current loop" (ie is it in "current mode control"?)...if so, then the double pole at the output is taken care of by the current mode control.
If your voltage loop is using "voltage mode control", then it would be different.
I'm not sure what you mean. Aren't RMS current and average current the same in this case? These measurements were taken by injecting a noise signal onto the current signal (inductor current or output current). The specific place of injection is between the current sense amplifier and the input to the microcontroller A/D channel. The method is similar to the method described here:
but injecting at a different location.
Sorry, I should have been more clear. These are closed measurements with just the inner current loop running (no outer voltage loop). The loop is compensated with a standard 2p2z compensator. The ~-20dB/decade indicates there is only one plant pole to compensate for. I was surprised to see such a pronounced resonant hump in the current loop measurements, which again makes me wonder if I have something setup incorrectly.
Agreed. I see the double pole when compensating the voltage loop.
Hi
In the inductor of an SMPS surely not.
RMS current and average current is only the same one pure DC (no ripple).
The average of a noise signal
* usualy is DC free => average current = 0.
* RMS is never zero
* RMS is never zero
Agreed, but I'm not sure why you bring this up.
The measurements are AC coupled with a bandpass filter at the injection frequency (so RMS measurements, along with phase).
because of this:
Difference:
If you have a SMPS output capacitor.
* there will be ripple containing input current
* there will about clean DC output current. (low ripple)
If you compare both RMS currents, they will differ.
If you compare both average currents, they will be the same.
The "Difference" may be explained by the use of wrong "current measurement method" (RMS instead of average).
--> comapre average values only.
    with2ls
The bode plots in post #3 demonstrate how current loop gain depends on output load. In this case, the output load is apparently purely capacitive, load capacitance is in the same range as output filter, thus about 6 dB gain difference.
Generally, changing output load also modfies loop gain. In case of output current measurement, the variation range is larer than with inductor current measurement, may involve stability issues.
    with2ls
The attached shows two Average current mode Bucks.....one is monitoring the inductor current, and the other is monitoring the post output capacitor current.
The one that monitors the inductor current needs the output of the current monitor to be filtered, so in fact, they are both effectively the same.
(LTspice sim and jpeg attached)
--- Updated ---
Its interesting because the ACM Buck, is from many viewpoints, a waste of time (ie just simply use a voltage regulation error amp instead).....however, when combined with paralleling of Bucks, then it can be useful as shown in the attached LTspice. Also, the other use for Average current mode in Bucks, AYK, is in the Half bridge (a buck derived converter), whereby ACM helps to keep the output capacitors balanced.....specially in situations like overload.......but even then, an output current clamp, rather than full ACM, seems more pertinent.
  • ACM Buck 36v to 12v at 10A.zip
  • Parallel Bucks_with ACM.zip
    with2ls
