Deepon
Member level 1
Hello,
I am currently willing to design circuits using the Barkley's BSIMSOI model file. I have downloaded the verilog-A code, but during simulation in Cadence, it is asking for the values of the following parameters:
I don't know where to find the proper values of these parameters, I searched the maunal, but no use. Can anyone help me out on this? I am willing to operate it in the 45-28nm regime.
Name | Description | Units |
Id | Drain current | amperes |
Ig | Gate current | amperes |
Is | Source current | amperes |
Ie | Substrate current | amperes |
Ip | External body current | amperes |
Ib | Internal body current | amperes |
Power | Total dissipated power | watts |
Vds | External drain-source voltage | volts |
Vgs | External gate-source voltage | volts |
Ves | External substrate-source voltage | volts |
Vps | External body contact to source voltage | volts |
Vbs | External source to internal body voltage | volts |
Ids | Internal drain-source current | amperes |
Ibd | Internal body-drain current | amperes |
Ibs | Internal body-source current | amperes |
Isub | Internal impact ionization current | amperes |
Igidl | Internal GIDL current | amperes |
Igs | Internal gate-source tunneling current | amperes |
Igd | Internal gate-drain tunneling current | amperes |
Igb | Internal gate-body tunneling current | amperes |
Igcs | Internal gate-channel tunneling current at source side | amperes |
Igcd | Internal gate-channel tunneling current at drain side | amperes |
Vdsat | Drain-source saturation voltage | volts |
Vth | Threshold voltage | volts |
Qg | Internal gate charge | coulombs |
Qb | Internal body charge | coulombs |
Qd | Internal drain charge | coulombs |
Qs | Internal source charge | coulombs |
Gmbs | Body transconductance | siemens |
Gm | Forward transconductance | siemens |
Gmids | Gm/Ids | 1/volts |
Gds | Output conductance | siemens |
Cgg | dQg/dVgb | farads |
Cgd | dQg/dVdb | farads |
Cgs | dQg/dVsb | farads |
Cbg | dQb/dVgb | farads |
Cbd | dQb/dVdb | farads |
Cbs | dQb/dVsb | farads |
Cdg | dQd/dVgb | farads |
Cdd | dQd/dVdb | farads |
Cds | dQd/dVsb | farads |
