bias for high gain opamp
rajblr
Junior Member level 3
Hi every one i am designing a BGR for low power specifications, which uses a high gain opamp. I am not so sure how to design a BIAS circuit for opamp to generate a current of 3uA.SO if any one can give me details or design method how to design a bias ckt it will be a great help............
TIA
raags
u can use the Vbg/R current to bias it , but u will nedd some start up circuit
hi can you just eloborate vbg/r means.........
Ok , i now think Vbg/R is not a good choice as u will need a buffer, so maybe the better choice is to use a constant gm current
for the bias , but here u will also need a start up circuit.
refer to razavi for more details on the constant gm current
