nelsonys
Member level 4
I have come across Intel board design which is designed in a rather confusing way.
Sorry it's a classified document which I'm not able to show it here and I'll try my best
to explain in words.
The PCB designers of Intel squeezed 4-5 traces in between breakout pins from BGA.
These traces need deskewing using serpentine routing before reaching the connector.
One thing confused me is that the board are well impedance controlled, but the trace
width themselves varied from portion to portion.
Say from breakout, the width is 0.1mm, after passing breakouts pins the width changes
to say, 0.15mm with wider clearance in between each traces.
Questions are:
1) Do they need to consider the strong coupling between traces at the breakout portion?
2) How did they manage to control the impedance to 50ohm by having two trace width?
3) Weird stackup by having two signal layers (even though contains differential signals)
sandwiched in between Power layers.
Besides, I would like to ask for opinion regarding inductor layout for power supply.
I come across a board design with the portion of the power layers (GND and VCC) under
the inductor being deliberately removed for the sake of EMC measures.
From my understanding, if there's no direct return under the inductor, it might as well
radiates EM field to the outer world isn't it??
Thanks,
Nelson
Questions are:
Thanks,
Nelson
