vasudevan.palani
Newbie level 3
I am planning to do home automation using microcontrollers.
The application has to be power efficient, Normally a +5 is required all times to make the relay close the circuit.
Latching relay seems to be a good option, however, have couple of concerns though
1. I think, it can be only switched on ( just like traic ), cannot be switched off ( isnt that so ?)
2. I dont get latching relays in my place.
Requirement, i should be able close a AC circuit ( 230V, 4A, 50Hz ) from a Microcontroller I/O pin. I should also be able to open the AC circuit as well.
IGBT seems to be a good, however, its very costly.
Is there any other cheap and energy efficient solution?
-Vasu
-Vasu
