tisheebird
Member level 5
I have designed a circuit and it gives me expected output. And when I plot s-plane plot with poles and zeros it looks like this:
Position of poles:
1st pole: -5 MHz
2nd pole: -33 MHz
Position of zeros:
1st zero: -33 MHz
All the poles and zeros are only on the real axis (no imaginary term) on LHP. The 2nd pole and 1st zero always coincide with each other regardless to temp, process variations. I would say the effect of the 2nd pole cancels out with a zero in this case.
Is it a 1 pole system..??
Is it stable as damping ratio(zeta) will be always more than 1 because roots like on - Real axis. Please help me..
Position of poles:
1st pole: -5 MHz
2nd pole: -33 MHz
Position of zeros:
1st zero: -33 MHz
