beep tone sending via PC modem
bunalmis
Full Member level 5
Ireland
I call any telephone number using ATDT command.
Telephone ring begin to working this is not problem,
I want to send 3 different beep sound (or any 3 different sound)
to telephone.
how?
I will use only PC and PC modem.
First, your modem has to support Voice Command (V.253, IS-101)
Then, use AT+VTS to send voice tones (DTMF and/or dual tone with duration selection)
Or use AT+VTX to playback a voice (PCM,ADPCM,LINEAR,uLaw,ALaw...)
This way will be needed more commands (+VSM,+VLS,+VPR..., and <DLE> shielded codes).
Of course, do not forget the master command: AT+FCLASS=8 (select voice mode).
FYR
hi! and is it possible to receive/decode some DTMF tones with a voice modem too? :puppydogeyes:
Modem will recognize and report the DTMF tones to DTE via <DLE> Shielded Codes.
Thank you Yager,
Can you write very simle code for this purpose and can you
post in this group? (Programming language not importand)
...or better post a link to some good voice modem commands/codes workings on the net. thanks. :)
AT Command Set: to use the best search engine in the world - Google, you will find more and more.
If you are so lazy, try this one: **broken link removed**
To send tones via voice modem: try these by any RS-232 console:
DTE.Tx          DCE.Tx
AT+FCLASS=8     OK
AT+VLS=4        OK
AT+VTS=0        OK
you will hear tones from the internal speaker of voice modem
To gather DTMF codes via voice modem:
DTE.Tx          DCE.Tx
AT+FCLASS=8     OK
AT+VLS=0        OK
AT+VRA=0        OK
ATDT911         OK
now pick up the phone and press 123, the DTE.Rx will get: <DLE>1 <DLE>2 <DLE>3 ('<DLE>' as ASCII 0x10)
To learn more, study before asking....
