avr programming in AVR Studio and CodeVision
ghoola
india
how can I change this AVR studio code to Codevision code?
 SPCR = _BV(SPE)|_BV(MSTR)|_BV(SPR1)|_BV(SPR0)
The definition of _BV is
#define _BV(bit) (1 << (bit))
so basically your code is
SPCR = (1<<SPE) | (1<<MSTR) | (1<<SPR1) | (1<<SPR0);
If the SPE,MSTR,SPR1 and SPR0 bits are not defined in codevision then check the datasheet and either add the definitions or replace them with numbers.
what do you mean check the datasheet?
The datasheet lists all the registers and the names of each bit of the register
The register you refer to is
So if the definition don't exist in codevision you can either add them or replace the bit names with the bit number
you mean like this
SPE 6
Yes
#define SPE 6
but maybe it's already implemented in codevision and you don't need to add it.
and one more thing should I define the reg SPCR at first?
I would expect the register names to be already defined.
You can try to compile your code, if any name if undefined you will get an error and then you can fix it.
You can also check the content of the header that codevision attaches in the project (the specific mcu model defines).
Reactions: ghoola
    ghoola
thank you so much dear alexan_e
Which version are you using, is it 2.x or 3.x ?
And which MCU model?
In version 2.03.9 there is only
sfrb SPCR=0xd;
The bit definitions got added in newer versions, like 2.6 or 3.x
so if i download CV version 2.6 or 3.x everything going to be ok?
Yes, these versions include additional headers with definitions for the bit names (e.g. mega32_bits.h)
Reactions: ghoola
    ghoola
