As you probably know, you need a programmer when you use microcontrollers. It is a DIY project of a board for AVR-Doper programmer. This programmer is made in SMT technology (except configuration jumpers) with microcontroller Atmega8L. The programmer has no virtual COM port (pins were not derived).
The system was programmed directly after soldering the microcontroller using additionally mounted „moustache” to the corresponding boxes (not mounted resistors, additionally derived box of RESET pin). Program for the microcontroller can be downloaded from LINK. The board was made by thermal transfer method using an envelope made of mozaics of two layers, it was heated by a laminator. Remember that the laminate, on which you want to apply the patterns of boards, should be rather thin (but not too much), because it eliminates the offset between the layers.
The programmer operates i WIN7 x64 in HID mode (configured with the jumper), it is supported by SinaProg (AVRDUDE overlay).
Link to original thread (useful attachment) – Programator mikrokontrolerów AVR (bazujący na AVR-Doper)
