Audio channel connection between GSM Module sim300c and PC
sahin5002
Member level 2
Bangladesh
I need to select an audio codec IC to convert analog voice of sim300c into PCMU/PCMA and inversely PCMU/PCMA signal is convert into analog voice which is connect with the mic of sim300c.
Need suggestion for choosing the chip and also schematic .
please check, does u r modem supports PCM, which gives you digital interface using internal codec...
Modem gives MIC and speaker outputs directly on the board. you can connect directly. I used to connect it directly. but the volume will be too low.
If I connect the mic and speaker directly with the soundcard, i know its work. but i have to connect more then 1 module with PC. So I need an ADC,DAC IC for each module.
