ATMEGA16 with Real time clock
Kaze105
Junior Member level 1
I am hoping to connect a real time clock to the ATMEGA16. A 32.XX (forgot exact number) Khz crystal oscillator is connected to the ports of TOSC1 and TOSC2.
I am using codevisionAVR to program the ATMEGA16 using a development board.
I am having trouble displaying the time onto the LCD display (which displays other things just fine).
I am hoping someone could help me with the coding for this.
I also do have a DS1672-33 external real time clock, but have yet to use it due to being unsure how to program it properly.
(In simple, hardware connections are just fine, i just need help with the coding using codevision AVR.)
Could you post your code rather than simply asking your problem so that everyone can give solution... Timer/Counter2 can be used as asynchronous communication [RTC] by setting AS2 bit in ASSR[Asynchronous status register] register..
Here is the code within the main(void)
 // Timer/Counter 2 initialization
 // Clock source: TOSC1 pin
 // Clock value: PCK2/128
 // Mode: Output Compare
 // OC2 output: Disconnected
 TCCR2=0x05;
 ASSR=0x08;
 TCNT2=0x00;
 OCR2=0x00;
I have it set up with the interrupt with the code below:
interrupt [TIM2_OVF] void timer2_ovf_isr(void)
       if(++time.second > 59)  // if seconds = 60
  time.second = 0;  // set seconds to 0
  if(++time.minute > 59)          // if minutes = 60
   time.minute = 0; // set minutes to 0
   if(++time.hour > 12)    // if hours = 13
    if(dayornight == 0) // if AM
    dayornight = 1;     // change to PM
    else
    dayornight = 0;     // make AM because already PM
    time.hour = 1; // change to 1 O'clock
   /*** Definitions for printf() statements***/
   // 20 scroll off so when at bottom row goes to top
   // 17 set cursor postion
   // 4 go to column 5
   // 3 go to row 4
        if (timedisplay == 1)
        if (dayornight == 0)
        printf("%c%c%c%c%02u:%02u:%02u AM",20,17,4,3,time.hour,time.minute,time.second);
            else
                printf("%c%c%c%c%02u:%02u:%02u PM",20,17,4,3,time.hour,time.minute,time.second);
           if (timedisplayset == 1)    //to display first feeding time set when setting
        if (dayornightset == 0)
        printf("%c%c%c%c  %02u:%02u AM",20,17,4,3,timeset.hourset,timeset.minuteset);
            else
                printf("%c%c%c%c  %02u:%02u PM",20,17,4,3,timeset.hourset,timeset.minuteset,);
           if (timedisplayset2 == 1)
        if (dayornightset2 == 0)
        printf("%c%c%c%c  %02u:%02u AM",20,17,4,3,timeset2.hourset2,timeset2.minuteset2,);
            else
                printf("%c%c%c%c  %02u:%02u PM",20,17,4,3,timeset2.hourset2,timeset2.minuteset2,);
Code is made so that when I enter timedisplay=1; in the main(void), the time will appear on the LCD.
I know the LCD works with other simple printf statements, but when I try this, nothing is displayed onto the LCD.
I want to implement digital clk using seven segment display plz help me.............dear's
