Assura RCX error: Bad return status
vsix91
Newbie
Hi everyone!
Can anyone explain to me why the rcx run failed and i get this error?
the following is the last statements of the log file with the warning and error.
****** For command L528 on processor #1:
*INFO* at "xreduce": mFactorR set to infinite
*INFO* at "xreduce": Processing mosne_dev_MOS_1.trans.pa (3072 transistors)
*WARNING* at "assura_rcx": the command was terminated
*ERROR* at "assura_rcx": Error: command failed with status 1
*WARNING* Bad return status from RCX run. 0x100.
i tried to run different extraction type with RCX (only C, only R and both) but doesn't change
I'm using ASSURA 4.14HF with Cadence IC 5.14
i have attach the log file of RCX run.
would appreciate if anyone can help me asap.
Thank you.
  • RCX_log.txt
