assignment comparison in verilog
eda_student
Newbie
what is difference between following 2 assignments?
always @(*)
    begin
     out_data = in_data;
     end
assign out_data = in_data;
the physical hardware generated by both statements will be the same.
there is only one verilog conceptual difference that the assigned inside the always block can only be done to a *reg* datatype. the assignment using the assign keyword can only be done to a *wire* datatype.
Synthesis treats the the two construct the same here. But one significant simulation difference is the always @* waits for a change on the RHS first before executing the assignment. If the RHS is a constant, it won't work.
The continuous assign statement executes once at time 0. The SystemVerilog always_comb statement does that too.
LaTeX Commands Quick-Menu:
