[AVR] ask about atmega32 pins
ghoola
Member level 2
Member level 2
india
guys I have a question about atmega32 pins can i make pc0 to pc7 inputs with programming and connect a LCD to those pins?
Yes You can connect the PINS to LCD, but there is SDA and SCL lines also in that PORT so basically if you have Deigns issue (i.e. No other Options Left)
then just Connect PC-4 to PC-7 to LCD'data pin DB-4 to DB7
Minimum 4 pins (for Data Lines) are enough to Display
But if you have other PORT options Just go for other
Reactions: ghoola
    ghoola
