Brainfart, makes no difference. He might consider a simple buffered inverter logic gate if he can live with the threshold tolerances.Hi,
Why 100 dB?
My calculation says 42 dB.
Klaus
Hi,The 25 MHz * 4uA * 100 dB gain is impossible to achieve at present due to tradeoff for RdsOn*Coss product into a 30pF load. Internal dynamic current of CMOS increases with f will grossly exceed Iq. Maybe in future with SiC or better. What do you want to compromise? BW Iq or Av? What source impedance, voltage, load and input/output dV/dt are you trying to compare ? Is the real question.
Hi, is there any reference how to make this prediction?Hi,
Why 100 dB?
Klaus
120V/V gain,
relax...I am asking about how I can make the prediction if the spec is possible...I am NOT asking about the conversion.Hi,
A_dB = 20 x log(gain_V)
... = 20 x log(120)
... = 20 x 2.079
... = 41.58 dB
rounded up to 42 dB
Decibel - Wikipedia
en.wikipedia.organd many million others:dB calculate - decibel calculation dB calculator voltage power ratio sound pressure level matching dBA SPL sound pressure intensity ratios converter thd percent % audio engineering impedance matching bridging - sengpielaudio Sengpiel Berlin
dB calculate dB calculator decibel calculator voltage power ratio reference voltage power level matching dBA dB SPL sound pressure intensity ratios converter thd percent % audio engineering impedance matching bridging - Eberhard Sengpiel sengpielaudio.comwww.sengpielaudio.com
https://www.google.com/search?client=firefox-b-d&q=db+calculation (190 million hits)
https://www.google.com/search?q=online+db+calculator (28 million hits)
Did you do some little effort to find out on your own?
Klaus
You want to build a single comparator to slice the incoming waveform, with the above spec.? This is looking very much possible to me. You can try with what is called strong-arm latch. I am sure if you switch it at 25MHz, you will not consume more than 5uA.Any recommended topology for comparator with 25MHz bandwidth, 120V/V gain, <4uA@1.2V current consumption?
65nm technology.
