Any one worked with TS-7800 board?
nkarnani
Newbie level 5
New Delhi,India
The thing is i have to make a program on my desktop with Ubuntu OS and the program is developed using Qt-Creator.
1)How can i test the program on desktop with sensor connected on TS-7800 board?
2)How can i transfer this program on TS-7800 board and make that program run from the board only.
Qt-Creator? Are you developing GUI application?
If that,you should cross-compile the QT library,and copy them to the rootfs,burst into flash.
Enable the kernel console to a UART.operate it with hyper terminal.
Be sure your driver works well before execute the GUI test program.
Good Luck!
