mr_anderson
Hi
Is there any relation between the antenna radiation pattern (although I know its a property related to the antenna) and the B.W of the modulated signal, I mean if we have a communication system and we set the Bitrate of the data to 1 Mbps then we set it to 10 Mbps will the radiation pattern change i.e. gets bigger or something like that ?
(assume we will use BPSK so the B.W=Bitrate).
for me I think the bitrate doesnot effect the radiation pattern at all, but I want to double check it with you guys.
Regards.
Anderson.
Regards.
Anderson.
