Ansys Electronic Desktop - HFSS 3D layout design to HFSS design
kovibb
Hi
Please can you advice to me how can i transfer (if it's possible) the HFSS 3D layout design (2D modeler) to to HFSS design (3D modeler)? I would like to at least check (by HFSS design view) if my 2D model representation, port definition etc. in HFSS 3D layout design is corrected setup.
Thank for any help
Hi, I'm also facing the same problem. Did you find the solution for this?
HFSS supports the import of a variety of 3D files. If you have a 2D file (*.dxf possibly?) you could import that and use it as the basis for drawing a 3D model for simulation.
Thanks for your suggestion.
But I'm working on IC layout and used ANF version for import in HFSS.
As it is IC layout, redesigning is not an option for me.
So, can you suggest any other option?
