Another tough 'elementary' question from my tutor
Yeah, but that solution violates the equipartition principle...
Did you mention that to your tutor?
Hi Jasmine, I wonder what's the period of the oscillation... shouldn't it be 0? wouldn't an oscillation with T=0, have an infinite frequency?... wouldn't it stop being an oscillation then?
I would like to know the answer just for curiosity. This problem is really interesting to me indeed. If you could give an explanation for the value of the period, or a mathematical expression or something it would be great.
thanks!
ch1k0, zero thermal energy does not mean zero total energy.
halls, T=0 and the infinite frequency do not disturb me, because the problem is
just mathematical abstraction. Mathematical, not physical.
Cheers!
Cheers!
zero THERMAL energy => no carrier can move , oscillation impossible, your answer can no work
if THERMAL energy no zero => carrier can move , equipartition rules, no oscillation
invent problem to fit your answer ?
"Zero THERMAL energy => no carrier can move".
"If THERMAL energy no zero => carrier can move".
Fudge.
jasmin_123 said:
halls, T=0 and the infinite frequency do not disturb me, because the problem is just mathematical abstraction. Mathematical, not physical.
Erhm... i believe there is some paradox in your proposition. In such an oscillation, with infinite frequency, if I am not wrong, there will be infinite energy, thus, energy conservation can't be considered (thought it was a premise)...
What am I missing?
jasmin_123 said:
Mr.MEB said:
and what is the limit when R-->0.
For R-->0, the limit is: a half of the energy is dissipated.
But for an R=0, no energy is dissipated. This is singularity!
Oooooh!!!
We have allways dissipation when we charge a capacitor.
When the charges are taken to plates of a capacitor by electromotive force we add energy to the system of charges between the plates.
But the charges forced by energy source (produce electromotive force) receives energy to do it.
The charges suffer allways a desacceleration to rest in plates.
The dissipation of the energy is a consequence of this.
Heat, Electromagnetic Radiation, etc
We can't stop in Snow with a car when we see a obstacle!!!:D
Fudge.
please explain english.
you invent impossible answer ?
jasmin_123 said:
Fudge means nonsense.
your solution makes no sense ?
or carriers in absolute zero move in your invented solution ?
I think that the above posted remark from the textbook should be noticed. It says, that even with no energy losses in the system, part of the energy would be transmitted as electromagnetic waves. If loss resistance is assumed as zero, the time constant is also zero, resulting in a current flow with infinite bandwith. Thus any energy amount necessary for charge conservation law have it's way could be radiated. As a result, the final voltages are identical to the real world case with R > 0.
Regards,
Frank
They do move as in many superconducting devices.
not absolute zero...
"Though it is not possible to cool any substance to 0 K,[2] scientists have made great advancements in achieving temperatures close to absolute zero..."
https://en.wikipedia.org/wiki/Absolute_zero
read , learn , talk.
order important.
https://en.wikipedia.org/wiki/Equipartition
invented problem for solution.
wrong order!
ch1k0, do you insist that an electron at absolute zero temperature cannot move in an electric field?
in the instant the electron starts moving, the temperature is absolute zero no more... it will be 0,0000000000000000001 K if you like, but not 0
If an electron moves not randomly, for example, it deterministically drifts in an
electric field then its temperature does not increase. It will remain absolute zero.
ch1k0 and halls, ask physicists if you do not believe me. I have asked some of them today,
just to be on the safe side. :)
Take care!
Take care!
The original thread is diverging...
Any comments on the elegant math to resolve the two capacitor paradox that the *physicists* published in the papers I posted ? It seems more relevant... I thought it kind of neat, and they use the word "fudge"!
Absolute zero is a theoretical state, so many funny things happen. Quantum effects, you know. It's impossible to reach this state, so you should ask a theoretical physicist (a condensed matter one, avoid the cosmologists...)
BTW, you should consider yourself pursuing theoretical physics as a career...
Assuming classical model (bohr atom, etc) I would say that no current would flow in any material where all the outer shell electrons are in the ground state (filled valence band).
Think semiconductors...
Metals would conduct, since there are always electrons in the conduction band.
*Some* materials would super-conduct, but then you need to get out of the classical model...
Since one can pick and choose which laws are valid for your mathematical abstraction, one can probably define an infinite number of mathematical solutions.
