Hi there, I am deal with the And-Or-Invert (AOI) of the XOR gate. But I not sure what I draw is appropriate or not.
Here is my gate drawing:
There is 2 inverters at the 1st AND gate. I just want to know if I am in the right way of drawing an AOI model.
Please advice. Thanks
Friends
See below please:
((A'*B')*AB)'=(A'B')'+(AB)' =(A+B)+A'+B'
Respect
Goldsmith
Oh sorry i thought that your out put gate is nand. yes it is correct . ( the final gate is nor ) . ok it is correct.
Again Sorry
So, is it ok if I put 2 inverter to the 2 inputs in the AND gate? Will it violated the AOI design rule?
Hi friend.......
Would you elaborate your question?
Thank you....
Hi friend.......
Thank you....
Alright. My question is, I would like to design an And-Or-Invert (AOI) gate. So, is it anything wrong the way I design the gate as above? Because I see most of the AOI gate, they just involving the AND gate and NOR gate but no NOT gate is involve.
I just worry there is rule on designing the AOI gate which cant be violated.
Thanks
---------- Post added at 10:32 ---------- Previous post was at 10:31 ----------
Sure. My question is, I would like to design an And-Or-Invert (AOI) gate. So, is it anything wrong the way I design the gate as above? Because I see most of the AOI gate, they just involving the AND gate and NOR gate but no NOT gate is involve.
Thanks
Friend .........
As per my knowledge, there is no violation in your circuit. Because, we want XOR output by using AND, OR, INVERT gates...
They may use NOR gate instead of OR, INVERT gates........
