Analog reading by ADC
a8811323
Newbie level 6
Here is the problem I have. If I have a near square wave signal biasing at 0V with +-3V and this signal is feeding into ADC with reference voltage 0 to 3.3V.
What I interest is the only peak magnitude value of square wave (the negative part is actually not interested). Can I do so? Will this negative part signal will affect the circuit and reading?
Normal guidelines state that inputs should not be exposed to a voltage outside the supply rails. There are diode arrangements that can block a negative waveform from reaching your input.
That would depend on whether the ADC is set up to accept negative-going signals. The "Auto-ranging DMM" pdf has an example of a precision rectifier - which sounds like the thing you want; the second pdf is a handy reference for all manner of set-up.
  • Building an Auto-Ranging DMM an028 Intersil.pdf
  • Buffer Op Amp to ADC Circuit Collection sloa098.pdf
If the ADC will survive, and if the ADC will operate correctly is written in the datasheet.
Klaus
No. Don't do it.
First perform a level-shift and then divide the input voltage.
This can be done by applying superposition techniques.
