yassin2705
Junior Member level 1
circuit design flow
Hi friends,
I am starting to design a folded-cascode fully differential amplifier OTA with CMFB. I am confused and don't know how to start because of the large number of mosfets. I know that the ideal flow is to start with hand analysis then move to the simulation stage, but I have two problems with hand-analysis, first is the large number of assumptions that i should made because of the large number of parameters. Secondly, the hand analysis results are not accurate anyway, so does it deserve all that effort!!
Also, I think in the simulation stage, we should divide the circuit into many subcircuits taking into consideration the loading between these subcircuits, is taht correct??
Also, how to select the optimum mos device from the available mos devices in the design kit??
I want an advice from analog desin experts to know the optimum flow.
Thanks!
yassin
Hi friends,
Thanks!
yassin
