[SOLVED] An equivalent circuit for the simple code below
vaah
Member level 3
Member level 3
US
Hi guys,
I have a simple code and I want to simulate it in cadence but I'd rather not use Verilog-A. I appreciate your thoughts and comments if anything crosses your mind!
if ((V(WL)-Vth)>0) VDC=2;
else VDC = 0;
Also, during the simulation, if one time "VDC=2" happens I don't want it to change "VDC" anymore.
Thank you.
Use a comparator to compare V(WL)(+) against Vth(-) . If V(WL)>Vth, the comparator output is high. That turns on a switch to pass 2V. If not, turns off the switch and ground the switch output.
Thank you very much for the reply.
There is only one problem, the output will change every time V(WL)>Vth. But I want it to keep the value.
You could use a comparator and a switch.
Thanks a lot. Doesn't it change the output for every cycle? I am looking for sth that keep the value after the first time V(WL)>VTH.
I actually want to use the minimum # of elements as it will drastically increase my simulation time.
What do you mean "every cycle"? The answer fits your original equation. Are you changing the equation??
Do not understand it either.
My bad, I forgot to add this part. I think you got my point now.
While (Clock) being
else VDC = 0;
end
Assuming VDC=2, I want it to happen only one time. For example, a capacitor can store the value. The thing is that I don't have ideal elements and I have to use actual transistors and capacitors.
So use a comparator AND a latch. When the comparator toggles the first time, it will trigger the latch that can control a switch.
Thanks, "barry".
That works but a comparator needs at least 4 elements and a latch 8 elements. It doesn't work for me as it needs at least 10 elements. I was thinking of sth with less than 10 elements.
