Mircusx
Newbie level 6
Hi everyone!
I'm trying to use the AMS hitkit 4.10 Cadence IC 6.1.7 on CentOS 7. Just after installation I created a new project in order to make sure the hitkit worked properly. I have set the model libraries and the simulation files in ADE L before launching the simulation.
When I launched the simulation, instead I got the following:
At this point I saw that someone else had the same problem (https://community.cadence.com/caden...ing-spectre-in-command-line-warning-and-error), so I followed the solution proposed in the link.
Thus I added the following line to my bashrc file
When I tried to run again the simulation, I got the following new errors and warning:
Has someone already had the same problem? Any help is highly appreciated
Warning from spectre during circuit read-in.
WARNING (SPECTRE-12030): The environment variable `AMS_processOption' is not defined, replacing with empty string.
Error found by spectre during circuit read-in.
ERROR (SFE-868): "/home/psei/eda/ams/spectre/c35/soac/processOption.scs" 7: Can not open input file `/home/psei/eda/ams/spectre/c35/processOption/.scs'. No such file or directory. Ensure that the file exists and the path to the file is correct. Otherwise, use the -I<path> command-line option to specify the path of the file.
export AMS_processOption=C35B3ALL
Unfortunately there are multiple warnings and errors with the already cited codes.WARNING (SFE-2654): VerilogA module `cmim_ahdl' override primitive/(verilogA module) `cmim_ahdl'.
ERROR (SFE-59): "/home/psei/eda/ams/spectre/c35/soac/process.scs" 26: Parameter `cj1' was previously defined. Please try to add `+spice' in command line or option `redefinedparams' in netlist to avoid these type of errors.
Error found by spectre during hierarchy flattening.
ERROR (SFE-9): Parameter `cj1' specified in multiple process vary statements.
ERROR (SFE-10): Parameter `mv_modn' specified in multiple mismatch vary statements.
