neazoi
Advanced Member level 6
I set the old Yaesu FT-101E for AM transmission as described in the manual and I get 20-25W carrier (ok) and when I speak to the mike, I only see the external wattmeter needle I have, move just a little.
Shouldn't I see a big movement in the meter upwards?
Also, A yaesu FT-301 does the same thing. In comparison a kenwood ts-480 outputs a 40W carrier which goes to 80W when I speak loudly. But it may be over modulation, I do not know, cause there is an ALC modification inside.
What is the case with AM, should I see the wattmeter needle move much, above the carrier, like in SSB or not?
The way I am thinking it is like SSB. But instead of zero output, I should see the idle carrier. Then, like SSB, when I speak to the microphone, I should see the power meter going up, peaking towards the full output power capability of the transmitter.
I assume an upwards AM modulation in my post.
I read this article https://ham.stackexchange.com/quest...m-transmitters-increase-when-modulated-and-of and now I am more confused.
Clearly in an upwards AM, the carrier should be set to 25W and one should expect 100W PEP.
He says "The carrier average power will be 2/3 of the 100% of the modulated average power.
Does it mean that the carrier level also goes up and down with the modulation?
I thought that the carrier would stay at the same level when modulation applied and only the sidebands go up and down!
Shouldn't I see a significant movement of the needle of the average power level during AM modulation?
--- Updated ---
