Amplifier with very low input referrd noise (less than 2nV)?
yolande_yj
Full Member level 3
lsk389 amplifiwer
How to design an low noise amplifier (BW<1K) that has very low input refer noise (or very low offset) ? I think Autozero and Chopping is not good enough. If I can use offchip JFET like LSK (**broken link removed**), how to do the following design?
Also, I found an ultra low noise OpAmp from TI (OPA228: http://focus.ti.com/docs/prod/folders/print/opa228.html), the input referred noise is only 3nV/srHz, how can they do that?
lsk389 + noise
Look a Datasheet on MAX4106 (0.95 nv/sqrtHZ, 2,8 pa/sqrtHZ) and read a book Motchenbacher C.D. Connelly J.A."Low-noise electronic system design ".
Best regards....
    yolande_yj
As I know, AD797 is also a very low-noise opamp. If you use CMOS, it is difficult to reach this spec. I guess they have special technologies to support the low-noise design.
Re: Amplifier with very low input referrd noise (less than 2
chopper stablized and multipath feedforward compensation
