Altium - multi component-objects (VIAs) parameter edit
Bartart
Full Member level 2
Europt
Hi there,
I have a nasty task...
The PCB I've to redo there are VIAs with 3 different diameters.. Idea is to have one diameter for all VIAs.
Selection of all VIAs is easy, now I have problems how to automatically change the diameters of all VIAs.
Anyone any idea?
Thanks, Sasha
Found the solution :D
Tab PCB > drop down menu > Hole size editor > and change the diameter
Usually I will use PCB->PCB List and then change include only to "Vias". There you can edit the dia value.
