Altium Designer: Disable auto-removal of redundant traces?
JohnG300c
Sometimes i want AD to keep redundant traces (for instance when placing multiple VIAs on power pins). How can this be disabled on-the-fly when a trace is placed? I tried locking VIAs but they were still removed.
Re: Altium Designer: Disable auto-removal of redundant trace
Your redundant traces are being removed by "loop removal". You can turn off loop removal for individual nets by using the PCB Panel. Set the panel to display "nets", highlight the net you want, right click, choose "Loop Removal", and turn it off.
You can also right click on a track or via, select "Net Actions>Properties", and uncheck the box for "Remove Loops".
Finally, while interactively (manually) routing a track with a net assignment, you can hit "tab" to bring up the properties, and uncheck the box for "automatically remove loops".
Thanks a million, House Cat. I did turn off loop removal on a global basis. I find that loop removal is a feature i rarely use and i will enable it when needed instead of the other way around (all my traces are point to point so loops are really not an issue).
