[SOLVED] alternative for Enfora GSM0308-71
flashking
Full Member level 3
Hello
I have been working recenlt in GPRS with enfora gsm module
It is perfect but the problem is its soldering as it needs a complex connector and the the antenna connector is wire (coaxial, UFL) which might be cut when it is used
My question is "is there an alternative module that is professional like this one but comes in surface mount or similar packages
I don't mind learning new commands but if enfora has a surface mount module it would be very good
Thanks in advance
Partially solved
The most populer modules are SIMcom and Wavecom modules
but they lack a professional TCP/IP stack
TELIT modules have a very good TCP/IP stack with SMT footprint
