Altera Boot Nios2 from EPCS16 using cyclon3
ashraf123
Newbie level 3
I know that this question may have been asked a lot but I spent a lot of time trying in making the NIOS boot from the EPCS.
The QSYS project picture is attached.
I tried using the commands
sof2flash --input=output_files/TEST.sof --output=hw.flash --epcs --verbose ;
elf2flash --input=software/count/binary.elf --output=sw.flash --epcs --after=hw.flash –verbose;
nios2-elf-objcopy --input-target srec --output-target ihex sw.flash sw.hex;
Then the sw.hex is used with TEST.sof to generate the JIC file.
After programming, the NIOS does not start.
I can run the code from eclipse by
Run As -> Nios II Hardware.
Thanks.
Thanks for your reply.
I have already searched a lot in this topic but tried several times but with no luck.
Another question, assume I could run the program from eclipse, can I read EPCS hex file that I put with the SOF? Here I don't mean load the program but reading data.
Thanks
