hamsiii
Hello all,
I wanted to implement a control box to an oven that heats 400-500 degrees Celcius. I have thermocouples (J Type) inside the oven and it has 2 terminals outside. I came across a component called "infinite control switch" that can work in my situation, which acts as a variable resistor, I guess. I do not want to use any microcontrollers and also integrate an analog display to that box that reads the oven's temperature. So, box should adjust the temperature and I should see it on the analog display.
The circuit should start with a terminal of the thermocouple, then with a series connected infinite control switch and parallel connected analog display, ended with other terminal of thermocouple. Do I need anything else, as I am confused that 3 elements will work in this case.
To sum up, my question is; can I find a commercial product despite working on this project, otherwise can I use just these components to implement a box explained above?
Thanks in advance.
Thanks in advance.
