deperkin
Member level 2
Hiya all!
I am interfacing a sensor (that has been manually tried and tested), with a dual digipot (DS1868).
I have tested the code and digipot(s) extensively and i get the resistances to change correctly.
My problem however is i cannot get my simple ADC code to work.
I have a very simple code:
#include <18F2550.H>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#device *=16
#device adc = 10 // 8-bit resolution for Analog-Digital Conversion
#use delay(clock = 4000000) //20MHz clock used for timing
//--------------------------DEFINES---------------------------------------------
#define zero 0
#define bias 1
//--------------------------GLOBALS---------------------------------------------
unsigned long a2dval;
//-------------------------INCLUDES---------------------------------------------
#include "PINOUT.c" // general pinout
#include "DS1868.c" // driver used for digital potentiometer
void initialize()
SET_TRIS_A(0xFF); // PINS A0-A7 are inputs
setup_adc_ports(AN0_TO_AN1|VSS_VREF); // Set pins for Analog-Digital(A2D) Conversions
setup_adc(ADC_CLOCK_DIV_4);// Set A2D clock
set_adc_channel(0); // Set inital A2D pin (A0)
delay_ms(100);
read_adc(ADC_START_ONLY);
delay_ms(100);
init_pots (); //initialize
void main() {
int value,ival,jval;
initialize();
while(1)
ival=150;
while(ival<255)
jval = 150;
value = ival;
delay_us(20);
set_pot (zero, value);
delay_ms (200);
a2dval = read_adc(ADC_READ_ONLY); //read sensor
delay_ms (100);
while(jval<255)
value = jval;
set_pot (bias, value);
delay_ms (200);
output_high (PIN_B3);
delay_ms(200);
output_low(PIN_B3);
delay_ms(200);
fprintf(COMP,"%u,%u,%lu\n\r",ival,jval,a2dval);
++jval;
++ival;
This is pretty simple code, but I am getting a constant value of 32768 on the computer for my ADC reading.
I have tried to change from float to int to long and combinations... but still a constant value.
I have tried changing to 8-bit resolution... still no help.
I have tried not using VREF and using VDD instead, along with removing this reference... no change.
ALSO, i have tried removing the sensor input and putting in a POT, and still same constant number.
This is the only pin (other then the SPI and LED) that is being used on the PIC.
ANY thoughts why my ADC is not working????
Thanks!
#device *=16
#define zero 0
#define bias 1
void initialize()
delay_ms(100);
delay_ms(100);
void main() {
initialize();
while(1)
ival=150;
while(ival<255)
jval = 150;
value = ival;
delay_us(20);
delay_ms (200);
delay_ms (100);
while(jval<255)
value = jval;
delay_ms (200);
delay_ms(200);
output_low(PIN_B3);
delay_ms(200);
++jval;
++ival;
Thanks!
