[SOLVED] ADC gain error formula...........
engrMunna
Full Member level 1
ADC gain error is defined as the difference at the ful scale value between ideal and actual curves when off set error has been removed.
The formual generally used is given in the picture. The first term in the brackets is the Full Scale vlaue in terms of LSB. The second term is for removing the off set error. and (2^N - 2) is the ideal value. My question is that shouldn't this be (2^N - 1) ?? becasue the ideal full scale value is (2^N - 1) Thanks
The reason is that the second term is not V0...00 but V0...01, so inside the brackets you have ((2^N - 1) - (1)).
Anyway I'd expect V0...00
---------- Post added at 09:20 ---------- Previous post was at 08:41 ----------
Out of curiosity I checked the IEEE Std 1241-2010: the static gain is indeed computed betwee code 2^N-1 and code 1 as in the formula you reported - I'm not smart enough to understand why though :)
Reactions: engrMunna
    engrMunna
    V
Thanks! yeah I think the reason is that it is V00..01 and not V00..00
    V
